[OpenFOAM.com] complile v2006 with runTimePostProcessing functionality
Old   July 18, 2020, 00:30
Default complile v2006 with runTimePostProcessing functionality
shinji nakagawa
snak is on a distinguished road
A runTimePostProcessing functionality is not available in precompiled packages of v1912 and v2006.
With OpenFOAM v1912 I successfully compiled the source code and the functionality works perfectly. What I did is here. [OS: Ubuntu 18.04]
I tried to compile v2006 with the same way as v1912. Compilation itself was finished without an error. However, the runTimePostProcessing function is not usable. What I did is explained in this link. [OS: Ubuntu 18.04]
The compilation creates the following three files for runTimePostProcessing library.
    librunTimePostProcessing.so
   librunTimePostProcessing.so.8
    librunTimePostProcessing.so.8.2.0
With v1912, these files are stored in `$WM_PROJECT_DIR/platforms/linux64GccDPInt32Opt/lib`.
With v2006, these files are stored in the one more deep depth directory `$WM_PROJECT_DIR/platforms/linux64GccDPInt32Opt/lib/lib`. There is an additional `lib`.
If I manually copy the three files into `$WM_PROJECT_DIR/platforms/linux64GccDPInt32Opt/lib`, runTimePostProcessing function works perfectly.
I would appreciate any advice to correctly compile the source code of v2006 with runTimePostProcess functionality enabled.
With v2006, `$WM_PROJECT_DIR/platforms/linux64GccDPInt32Opt/lib/lib`directories contains many files. I'm not sure these libraries works or not.
snak is offline   Reply With Quote
Old   July 24, 2020, 07:05
shinji nakagawa
This problem is caused by "dash" used in Ubuntu. There are some related issues and solutions.
https://develop.openfoam.com/Develop.../-/issues/1782
https://develop.openfoam.com/Develop.../-/issues/1757
https://develop.openfoam.com/Develop.../-/issues/1541
https://develop.openfoam.com/Develop...on/-/issues/48
https://stackoverflow.com/questions/...m-makeparaview
Old   August 1, 2020, 08:08
shinji nakagawa
Developers debugged the code with this commit.
https://develop.openfoam.com/modules...645ef0ffc90272
[General] Paraview crashes using "Find Data" functionality Turbine ParaView 3 May 6, 2020 22:40
Multiphase ramping functionality sita OpenFOAM Running, Solving & CFD 7 September 18, 2019 13:03
face functionality for a DynamicList tomislav_maric OpenFOAM Programming & Development 2 November 30, 2011 18:04
Preview of Coming Equation Writing Functionality Peter Main CFD Forum 0 February 14, 2009 15:14
Does anybody use Commander with V3.6.1 or V2006? Dave Phoenics 0 February 9, 2007 13:48
