September 19, 2013, 03:17 |
Problem installing pythonFlu
#1 | |
Christoph Kratzsch
Hi Foamers!
First, thank you for developing a tool that merges Python and OpenFOAM. So now i want to use pythonFlu with OpenFoam-2.1.x. So i have downloaded all the sources and startet installing them as described here. The problem is mainly, that when i try to run the configure-script of managedFlu there is an error regarding C++ compiler. It states as follows: Quote:
So i don't figure it out how the skript tests, if the compiler works. Can i test it manually otherwise? My modified env.sh just make a path to some local directory for confFlu, where it is installed. My OpenFoam-2.1.x-bashrc should also work. Can someone help me with that? I am using a Debian Wheezy system (hopefully i'll need just some extra packages ;-) ) Best regards, Christoph |
September 19, 2013, 04:51 |
Joachim Herb
Rep Power: 21 |
Can you compile OpenFOAM itself (or your own solvers/tools)? Do have different compilers installed?
I tried to compile pythonFlu for OpenFOAM 2.2.1 and this didn't work very well (I had to exclude a lot of files). Probably the latest supported version 2.0.x. |
September 19, 2013, 05:17 |
#3 | |||
Christoph Kratzsch
Because i'm not familiar with pure C++-Programming i hope the follwing outputs answers your question: Code:
g++ --version Quote:
ls -l gcc* Quote:
Is this some useful information ? I think the latest supported OpenFOAM-version is 2.1.x as stated here. Best regards |
September 19, 2013, 06:25 |
Joachim Herb
Rep Power: 21 |
I think these posts might help with the selection of gcc versions in Debian:
http://lektiondestages.blogspot.de/2...-versions.html http://lukas.ahrenberg.se/archives/154 |
pythonflu |
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! | omid20110 | OpenFOAM Installation | 6 | August 1, 2016 11:20 |
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison | lxwd | OpenFOAM Community Contributions | 1 | March 20, 2016 16:03 |
Problem with installing OpenFOAM 2.0.X | mohsen.boojari | OpenFOAM Installation | 3 | February 3, 2016 11:41 |
Problem installing OpenFOAM-1.6-ext on Ubuntu 14.04 | afrotimy | OpenFOAM Installation | 4 | October 4, 2014 11:36 |
Problem in installing OpenFOAM-ParaView-0.1.1-1.x86_64 | hassan5565 | OpenFOAM Installation | 1 | August 5, 2014 13:05 |
