centfoam 2.2.x on RHEL 5.10 clone
Old   November 6, 2013, 16:53
Default centfoam 2.2.x on RHEL 5.10 clone
Eric Paul
ericpaul is on a distinguished road
I just installed centfoam 2.2.x on a Springdale 5.10 (RHEL 5.10 clone) cluster in /opt so it can be used by all users. When I run the command 'mpicc --showme:link' I get the following output:
-pthread -L/home/centfoam/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/openmpi-1.6.3/lib64 -lmpi -ldl -lm -Wl,--export-dynamic -lrt -lnsl -lutil -lm -ldl
Notice the path for the link is /home/centfoam/ instead of /opt. With previous versions of centfoam the output gave the proper path to /opt. Is there an easy way to fix this.
The reason I as is my users are getting the following error when compiling with mlicc:
/usr/bin/ld: cannot find -lmpi_cxx
It seem it may be related to this linker having the wrong defaults.
Thanks
Eric
ericpaul is offline   Reply With Quote
Old   November 9, 2013, 12:00
Retired Super Moderator
Bruno Santos
Greetings Eric and welcome to the forum!
Try the instructions given here: http://www.open-mpi.org/faq/?categor...ng#installdirs
For example:
export OPAL_PREFIX=/opt/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/openmpi-1.6.3
But it's possible that Open-MPI 1.6.3 is no longer honouring these environment variables...
Best regards,
Bruno
Fluent compliance with RHEL 4 hervé FLUENT 2 January 25, 2006 04:39
