December 19, 2013, 12:40 |
Paraview version update errors
Dan Pearce
Rep Power: 12 |
Hi Foamers,
This is one of my first posts so please be gentle . I have been using openfoam V2.1.1 with paraview 3.12 for a while on ubuntu 12.04 without any problems. Recently I started experiencing severe memory leaks with paraview, each time I changed the timestep and re-rendered the graph the memory use would increase but it would never be released again. After some digging around I thought the problem may have been related to a known issue in paraview 3.12 so I attempted to update to 3.98.1 and this turned out to be a tricky job. Initially I tried to install the binary packs and just add a comment to the bashrc file to update the location but this gave a bunch of errors so I downloaded the source and attempted to build myself. After a bit of fumbling, I managed to build 3.98.1 and added the following to the bashrc file as per the message at the end of the build script: Code:
export ParaView_MAJOR=3.98 export ParaView_VERSION=3.98.1 export ParaView_DIR=/opt/ThirdParty-2.1.1/platforms/linux64Gcc/paraview-3.98.1 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.98 Code:
FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake Code:
dp1212@dp1212-T5500:/opt/openfoam211/applications/utilities/postProcessing/graphics/PV3Readers$ ./Allwmake + [ -d /opt/ThirdParty-2.1.1/platforms/linux64Gcc/paraview-3.98.1 -a -r /opt/ThirdParty-2.1.1/platforms/linux64Gcc/paraview-3.98.1 ] + [ -n /opt/openfoam211/platforms/linux64GccDPOpt/lib/paraview-3.98 ] + [ -n g++ ] + export CXX=g++ + wmake libso vtkPV3Readers mkdir: cannot create directory `linux64GccDPOpt': Permission denied /bin/sh: 1: cannot create linux64GccDPOpt/options: Directory nonexistent make: *** [linux64GccDPOpt/options] Error 2 /opt/openfoam211/wmake/MakefileFiles:40: linux64GccDPOpt/options: No such file or directory make: *** No rule to make target `linux64GccDPOpt/options'. Stop. To test if paraview is actually working, I run 'paraview' from the terminal and it appears to start up ok but throws an error when loading a .foam file as below (the example below is for loading gamma from a multiphase problem but the same occurs for k, rho files etc): Code:
ERROR: In /opt/ThirdParty-2.1.1/ParaView-3.98.1/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6478 vtkOpenFOAMReaderPrivate (0x3d6a4b0): Error reading line 17 of /home/dp1212/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phasecav2/0/gamma: Expected a number, found a non-digit character ] Thanks Last edited by wyldckat; December 25, 2013 at 06:16. Reason: Added [CODE][/CODE] |
December 25, 2013, 06:32 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Dan,
Nice! You've managed to build ParaView 3.98 from source code! That is quite a feat, specially if you haven't found some of the posts here on the forum explaining how that can be done Let me address the missing details in a bullet point list:
Bruno
December 27, 2013, 10:44 |
Dan Pearce
Rep Power: 12 |
Hi Bruno,
Thanks for getting back to me so quickly. I went through the links you supplied and tried to understand what was happening with the following results: - tried to build the Pv3readers after editing the vtkPV3FoamReader.h, vtkPV3blockMeshReader.h and vtkPV3FoamReader.cxx files. This seemed fine as it is using the new export class rather than the IO_Export class and removing the empty array pass through since the new pipeline does not use it any more. I couldn't find out where the option to turn on the paraview install development files was though. From the opt/ThirdParty-2.1.1 directory I then did ./Allclean and ./makeParaview version 3.98.1. Everything seemed to compile ok. - Next went and edited the bashrc file in the $WM_Project_dir and /bin paraFoam scripts as per #8 and #9. Trying to run paraFoam from the terminal still gives me the classic error Code:
dp1212@dp1212-T5500:~/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phaseLP$ paraFoam -builtin /opt/openfoam211/bin/paraFoam: 38: /opt/openfoam211/bin/paraFoam: source: not found FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake Code:
dp1212@dp1212-T5500:~/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phaseLP$ paraview ERROR: In /opt/ThirdParty-2.1.1/ParaView-3.98.1/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6478 vtkOpenFOAMReaderPrivate (0x328c070): Error reading line 17 of /home/dp1212/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phasecav2/0/gamma: Expected a number, found a non-digit character ] Are the two issues related? Ie is the non digit error related to the build process or just the foam reader build error? For info, here is the output from trying to build the readers: Code:
dp1212@dp1212-T5500:~/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phaseLP$ sudo su -c "source /opt/openfoam211/etc/bashrc; bash" [sudo] password for dp1212: root@dp1212-T5500:/home/dp1212/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phaseLP# cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers root@dp1212-T5500:/opt/openfoam211/applications/utilities/postProcessing/graphics/PV3Readers# ./Allwclean + wclean libso vtkPV3Readers wclean vtkPV3Readers + PV3blockMeshReader/Allwclean + rm -f /opt/openfoam211/platforms/linux64GccDPOpt/lib/libPV3blockMeshReader* + rm -rf PV3blockMeshReader/Make + wclean libso vtkPV3blockMesh wclean vtkPV3blockMesh + PV3FoamReader/Allwclean + rm -f /opt/openfoam211/platforms/linux64GccDPOpt/lib/libPV3FoamReader* + rm -rf PV3FoamReader/Make + wclean libso vtkPV3Foam wclean vtkPV3Foam root@dp1212-T5500:/opt/openfoam211/applications/utilities/postProcessing/graphics/PV3Readers# ./Allwmake + [ -d -a -r ] root@dp1212-T5500:/opt/openfoam211/applications/utilities/postProcessing/graphics/PV3Readers# Dan Late addition: I tried to get on with some work and fired up the previously working version of 3.12.0 and now it is broken as well! Code:
p, li { white-space: pre-wrap; } ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.x/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x3fc8020): Error reading line 17 of /home/dp1212/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phaseLP/0/gamma: Expected a number, found a non-digit character ] Purged the packages and reinstalled 3.12 and OF211 from apt and got back to a working system under 3.12. Using Brunos blog page from http://www.cfd-online.com/Forums/blo...-openfoam.html I removed the contents of the $ParaView_DIR folder and replaced it with the downloaded binaries. After some careful testing in some fresh terminals, it turns out that this only works when steps #8 and #9 are omitted. Paraview 3.98.1 now starts happily but is still giving the same error when attempting to load from a gamma file from a multiphase problem: Code:
ERROR: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6478 vtkOpenFOAMReaderPrivate (0x2762060): Error reading line 17 of /home/dp1212/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phaseLP/0/gamma: Expected a number, found a non-digit character ] Last edited by Dan Pearce; January 3, 2014 at 14:39. Reason: adding extra information |
January 3, 2014, 14:54 |
Dan Pearce
Rep Power: 12 |
Tried paraview 4.0 and similarly to last update, only works when omitting steps #8 and #9 and comes up
ERROR: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6478 vtkOpenFOAMReaderPrivate (0x27f0d00): Error reading line 17 of /home/dp1212/OpenFOAM/dp1212-2.1.1/run/tutorials/multiphase/cavitatingFoam/les/Mexus2phaseLP/0/gamma: Expected a number, found a non-digit character ] Code:
ERROR: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/Common/DataModel/vtkDataObjectTree.cxx, line 377 vtkMultiBlockDataSet (0xe1a1430): Structure does not match. You must use CopyStructure before calling this method. |
January 4, 2014, 19:42 |
Bruno Santos
Rep Power: 128 |
Hi Dan,
Sorry, I've been a bit busy and I was thinking about helping you by writing down some instructions to rely on using Ubuntu's own ParaView builds... But I've ended up reviewing the last two posts and came to the conclusion that the best approach right now would be to diagnose the problem at hand. Therefore:
edit: Never mind, I've figured it out. The same problem occurs with the "throttle*" tutorials. The dimensions defined most of the field files are incomplete; for e.g. in the file "0/gamma": Code:
dimensions [0 0 0 0 0]; Code:
dimensions [0 0 0 0 0 0 0]; edit 2: Reported in the bug tracker: http://www.openfoam.org/mantisbt/view.php?id=1123 Best regards, Bruno
Last edited by wyldckat; January 4, 2014 at 20:17. Reason: see "edit:" and "edit 2:" |
January 8, 2014, 05:47 |
Dan Pearce
Rep Power: 12 |
Hi Bruno,
Many thanks for sorting this one out, I had not ever thought to look into the dimension specs for gamma and other files. For reference, I still had some consistent warnings come up using paraview 4.0 but 3.98.1 works very well for me, the original memory leak problem from 3.12 seems to have been completely resolved. Dan |
paraview 3.98 |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
[OpenFOAM] change in paraview 3.14 version | lakeat | ParaView | 4 | July 25, 2012 13:17 |
Qt version of Paraview 3.8.0 in OpenFOAM 1.7 | waynezw0618 | OpenFOAM Installation | 10 | March 3, 2011 08:53 |
[OpenFOAM] Problem with paraFoam on a linux-64 bit | bunni | ParaView | 4 | April 14, 2010 20:55 |
