Problem in running foam-extend-3.0/tutorials
Like Tree1Likes
  • 1 Post By wyldckat
Old   February 3, 2014, 03:40
Post Problem in running foam-extend-3.0/tutorials
sam.ho is on a distinguished road
I have installed foam-extend-3.0 in OpenFOAM/foam-extend-3.0
directory bu fallowing the instructions given in the
LINK : http://wikki.gridcore.se/foam-extend/download#compile
Later created a directory RUN in OpenFOAM/foam-extemd-3.0 and copied all the tutorials to this RUN directory and tried to run but I am not able to run tutorials .
What might be the problem, ???
Please help me
Regards..
Sangamesh Hosur
sam.ho is offline   Reply With Quote
Old   February 4, 2014, 15:11
Retired Super Moderator
Bruno Santos
Greetings Sangamesh,
Well, without being able to see what you are seeing, it's very hard to diagnose what the problem might be.
I suggest that you run the following commands, one line at a time, and let us know what do you get from the output of each command:
mkdir -p $FOAM_RUN
cp -r $FOAM_TUTORIALS $FOAM_RUN
cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
blockMesh
icoFoam
paraFoam
And make sure that you run the commands identically to the lines above, otherwise it will very likely not work as intended.
Best regards,
Bruno
sam.ho likes this.
Old   February 4, 2014, 22:35
Post Thank you
Hi ,
I copied the tutorials in $Home/OpenFOAM/foam-extend-3.0/run
But The path suggested by you has worked out.
Now my question is which solver need to choose for radial flow turbine which is rotating at 160000 rpm ?
Old   February 5, 2014, 16:01
Bruno Santos
Quick answer: I have no idea. But have a look into the wiki pages by the Special Interest Group for Turbomachinery: http://openfoamwiki.net/index.php/Sig_Turbomachinery
Beyond that, I suggest that you ask in the correct sub-forum
edit: Oh, I see now that you already did http://www.cfd-online.com/Forums/ope...lesrffoam.html
Old   February 5, 2014, 23:06
Thank you
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 06:44
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
