Third party installation problem in OpenFOAM-1.6-ext
Old   March 12, 2014, 03:50
Post Third party installation problem in OpenFOAM-1.6-ext
sam.ho is on a distinguished road
Hi Foamers,
I am facing some error while installing the third party in OpenFOAM-1.6-ext.
The problem is as follows..
What could be the problem ? How to resolve this ?
This system rpm command: rpm --force-debian
Starting ThirdParty AllMake: Stage1
Package name      : cmake-2.8.11
Package URL       : http://www.cmake.org/files/v2.8/cmake-2.8.11.tar.gz
RPM spec file name: cmake-2.8.11.spec
Additional flags  :
Updating the ThirdParty environment variables before building package cmake-2.8.11
Download cmake-2.8.11.tar.gz from : http://www.cmake.org/files/v2.8/cmake-2.8.11.tar.gz
--2014-03-12 14:06:27--  http://www.cmake.org/files/v2.8/cmake-2.8.11.tar.gz
Resolving www.cmake.org (www.cmake.org)... failed: Name or service not known.
wget: unable to resolve host address `www.cmake.org'
Making package cmake-2.8.11 using RPM.
Building package cmake-2.8.11 using SPEC file : cmake-2.8.11.spec. Optional args:
error: File /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/cmake-2.8.11.tar.gz: No such file or directory
Installing package: cmake-2.8.11
  Uninstalling cmake-2.8.11 using RPM: cmake-2.8.11-linux64GccDPOpt.x86_64
  Installing cmake-2.8.11 using RPM file: /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/cmake-2.8.11-linux64GccDPOpt.x86_64.rpm
error: open of /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/cmake-2.8.11-linux64GccDPOpt.x86_64.rpm failed: No such file or directory
Done installing package
Done ThirdParty AllMake: Stage1
sam.ho is offline   Reply With Quote
Old   March 12, 2014, 14:35
Retired Super Moderator
Bruno Santos
Quick answer:
  1. You need to manually download this file: http://www.cmake.org/files/v2.8/cmake-2.8.11.tar.gz
  2. And place the downloaded file in this folder:
Old   March 13, 2014, 06:03
Post
Originally Posted by wyldckat View Post
Quick answer:
Hi Bruno,
I have followed the same procedure which you suggested but still in thirdparty stage 3 scotch-5.1.10b is not installed . This log file content is as follows
Starting ThirdParty AllMake: Stage3
Package name      : metis-5.0pre2
Package URL       : http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/OLD/metis-5.0pre2.tar.gz
RPM spec file name: metis-5.0pre2.spec
Additional flags  :
Updating the ThirdParty environment variables before building package metis-5.0pre2
Package metis-5.0pre2 is already installed
Package name      : ParMGridGen-1.0
Package URL       : http://www.mgnet.org/mgnet/Codes/parmgridgen/ParMGridGen-1.0.tar.gz
RPM spec file name: ParMGridGen-1.0.spec
Additional flags  :
Updating the ThirdParty environment variables before building package ParMGridGen-1.0
Package ParMGridGen-1.0 is already installed
Package name      : libccmio-2.6.1
Package URL       : http://portal.nersc.gov/svn/visit/tags/2.4.2/third_party/libccmio-2.6.1.tar.gz
RPM spec file name: libccmio-2.6.1.spec
Additional flags  :
Updating the ThirdParty environment variables before building package libccmio-2.6.1
Package libccmio-2.6.1 is already installed
Package name      : mesquite-2.1.2
Package URL       : http://software.sandia.gov/~jakraft/mesquite-2.1.2.tar.gz
RPM spec file name: mesquite-2.1.2.spec
Additional flags  :
Updating the ThirdParty environment variables before building package mesquite-2.1.2
Package mesquite-2.1.2 is already installed
Package name      : scotch-5.1.10b
Package URL       : https://gforge.inria.fr/frs/download.php/27583/scotch-5.1.10b.tar.gz
RPM spec file name: scotch-5.1.10b.spec
Additional flags  :
Updating the ThirdParty environment variables before building package scotch-5.1.10b
Download scotch-5.1.10b.tar.gz from : https://gforge.inria.fr/frs/download.php/27583/scotch-5.1.10b.tar.gz
--2014-03-13 10:23:17--  https://gforge.inria.fr/frs/download.php/27583/scotch-5.1.10b.tar.gz
Resolving gforge.inria.fr (gforge.inria.fr)... failed: Name or service not known.
wget: unable to resolve host address `gforge.inria.fr'
Making package scotch-5.1.10b using RPM.
Building package scotch-5.1.10b using SPEC file : scotch-5.1.10b.spec. Optional args:
error: File /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/scotch-5.1.10b.tar.gz: No such file or directory
Installing package: scotch-5.1.10b
  Uninstalling scotch-5.1.10b using RPM: scotch-5.1.10b-linux64GccDPOpt.x86_64
  Installing scotch-5.1.10b using RPM file: /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/scotch-5.1.10b-linux64GccDPOpt.x86_64.rpm
error: open of /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/scotch-5.1.10b-linux64GccDPOpt.x86_64.rpm failed: No such file or directory
Package name      : ParMetis-3.1.1
Package URL       : http://glaros.dtc.umn.edu/gkhome/fetch/sw/parmetis/OLD/ParMetis-3.1.1.tar.gz
RPM spec file name: ParMetis-3.1.1.spec
Additional flags  :
Updating the ThirdParty environment variables before building package ParMetis-3.1.1
Package ParMetis-3.1.1 is already installed
Done ThirdParty AllMake: Stage3
Old   March 15, 2014, 03:27
Bruno Santos
Do you mean that you did the following for Scotch as well?
  1. You need to manually download this file: https://gforge.inria.fr/frs/download...5.1.10b.tar.gz
edit: OK, I've seen just now that you did that, as explained here: http://www.cfd-online.com/Forums/ope...tml#post479698 post #20
Then I'll switch this line of conversation to that other thread.
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
OpenFOAM 1.7.0 installation problem stevek OpenFOAM 14 December 1, 2010 15:30
Problem on Installing OpenFOAM 1.6 on Fedora 11 lzgwhy OpenFOAM Installation 1 August 25, 2009 11:02
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
