April 10, 2014, 06:03 |
Win 7 64 bit Installer ???
Rep Power: 12 |
Hi Folks =)
I downloaded what I thought was the installer from Sourceforge (after searching for "Win 7 version of openfoam") but I can't find an .exe file...??? I don't know beans about compiling and coding and all that (I don't even really know how to use the command prompt) =( But I really need OF to simulate differently shaped buoyant objects in a water column (and that's why I found OF in the first place...) Can anyone write me out a dummy's guide to installing OF? I tried wading through pages and pages of wikis but all seem to need me to know things I don't...I do have virtual box installed (a buddy helped me do all the steps for that =P ) Also, does OF have a GUI? Or maybe a real Win program would do? I just need to simulate the ascent rates of different buoyant containers in water columns of different heights and cross-sectional areas. So, for example, could I just draw out a 3D shape and state the liquid density, etc. and it will spit out answers? Sorry for the looong first post. I really need this software bad--or something that does the above... Thanks All =) |
April 11, 2014, 09:34 |
Bernhard
Rep Power: 21 |
What is your background? CFD is not something that you can just try out on a friday afternoon and expect reliable results. Even for experienced users it is not easy to get reliable results for things like ascents rates. Why did you choose OpenFOAM? Maybe it is better to ask your boss to either hire a professional consultant, or to send you to a CFD/OpenFOAM coarse.
April 11, 2014, 09:56 |
Rep Power: 12 |
Thanks for your reply, Bernhard.
I was looking for a simulation program to test different buoyant container shapes and their accelerations in water columns. I did a google search and OF was what came up...I thought it was a GUI that i could input the shape and other variables and get my answer...guess I was wrong =( I am an independent researcher and don't know anything about coding, scripts, command lines, etc. but I need to find an optimum container dimension and shape. Any ideas? Thanks a lot =) |
April 11, 2014, 16:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
There is a wiki page at openfoamwiki.net that tries to gather a complete list of GUIs available for using OpenFOAM: http://openfoamwiki.net/index.php/GUI For optimization, most of the multidisciplinary GUI's listed there will support parametric studies. Best regards, Bruno
April 12, 2014, 03:35 |
Rep Power: 12 |
Thanks for the suggestions, Bruno. I'll have a look. The thing is, I don't even know how to install what I downloaded. It's supposed to be a Win version, but it has no .exe installer...???
April 12, 2014, 16:12 |
#6 | |
Bruno Santos
Rep Power: 128 |
Hi lotuseater,
Yesterday I took the time to update the wiki page regarding GUI's and also regarding OpenFOAM on Windows: http://openfoamwiki.net/index.php/Windows With any luck, you'll find directions to the instructions you're looking for. By the way, did you try looking in Youtube for instructions on how to install OpenFOAM and Virtualbox and so on? Best regards, Bruno
April 13, 2014, 03:10 |
Rep Power: 12 |
Hey Bruno,
I mentioned that it was from sourceforge. The name of the main folder when unzipped is OpenFOAM-2.1.x and there are a few batch files along with it. Inside the main folder are three folders: bin, etc, and lib. I'll check out the updated wiki and thanks for the suggestion to look on youtube. But even if I do install it, I get the feeling it will require coding and scripting knowledge to simulate what I want (please see earlier posts). Or does it have a ready to go simulator for buoyancy and all that? Thanks. |
April 13, 2014, 03:35 |
Bruno Santos
Rep Power: 128 |
Hi lotuseater,
There are currently 4 projects on SF.net that provide some sort of port of OpenFOAM for Windows . I believe the support thread for the package you downloaded is this one: http://www.cfd-online.com/Forums/ope...g-openmpi.html When one is not familiar with a particular software, one should have a look into its manual Have a look at the first tutorial (of three) in the OpenFOAM User Guide: http://www.openfoam.org/docs/user/cavity.php Therefore, even though OpenFOAM does have a few buoyancy-based solvers, you'll need to go through steps like those on the User Guide. As for the optimization part, you'll then have to learn how to use Dakota and possibly pythonOCC. Good luck! Best regards, Bruno
April 13, 2014, 03:44 |
#9 |
Rep Power: 12 |
Thanks for the links
I did try to look into how to install and use the program but I was faced with about 40 links on one page I found alone :P At least you've directed me to the pages I should be reading, so thanks. I may not have the time to learn a language, but if it can simulate a few different shapes out of the box then it should be worth installing it. I'll post again if I really get stuck...lol |
gui, installer, similar software, windows |
[ICEM] Scripting language version for ICEM 14.0 on win 7 64 bit | Far | ANSYS Meshing & Geometry | 10 | August 26, 2014 05:46 |
compiled udf functions at fluent 15 win 8 64 bit | hillat | Fluent UDF and Scheme Programming | 2 | January 25, 2014 07:08 |
SU2 binary executables for Win 64 bit | JAlbert | SU2 Installation | 1 | January 11, 2014 21:20 |
[ICEM] Scripting language version for ICEM 14.0 on win 7 64 bit | Far | ANSYS Meshing & Geometry | 3 | May 21, 2012 14:09 |
STAR-CD v4.02 parallel problems on Win XP 64 bit | Kasper | Siemens | 3 | September 24, 2007 06:06 |
