ParaView Execute problem
Old   May 12, 2014, 06:31
Default ParaView Execute problem
insta is on a distinguished road
Hi everyBody,
Recently I had installed the new version of OpenFoam including ParaView (RedHat operating system). The OpenFoam is working well, but the paraview doesn't work when I try to open it with the paraFoam command. The error message is like this:
created temporary 'pitzDaily.OpenFOAM'
[xcb] Too much data requested from _XRead
[xcb] This is most likely caused by a broken X extension library
[xcb] Aborting, sorry about that.
paraview: xcb_io.c:735: _XRead: Assertion `!xcb_xlib_too_much_data_requested' failed.
Does anyone knows how to fix this problem??
thanks in advance
regards
Insta
insta is offline   Reply With Quote
Old   June 8, 2014, 15:36
Retired Super Moderator
Bruno Santos
Greetings Insta,
Almost a month later, but I've only just now managed to get to this thread of yours.
I don't know if you've managed to solve this yet or not, but if you haven't, we could use more information about your system and the installation instructions you've followed, namely:
  1. Which RHEL version are you using and is it fully up-to-date?
  2. Which installation instructions did you follow? The ones for installing from RPM on RHEL or for building from source code?
Best regards,
Bruno
Old   June 9, 2014, 02:37
Hi Bruno
Thanks for the reply.
I've already fix the problem by upgrading the operating system.
(The problem occured with an old version of open Suse).
Thanks
[OpenFOAM] Problem running paraview (libQVTK?) t_clark ParaView 2 August 8, 2012 05:23
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 18:13
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
[OpenFOAM] Problem with Colors in ParaView sven ParaView 1 May 31, 2009 08:13
