complile the Doxygen(source guide) of foam-extend-3.0 |
May 8, 2014, 23:59 |
xuhe-openfoam
Rep Power: 12 |
hi,
I have complied the Doxygen of foam-extend-3.0 ! Then I use firefox to open the index.html but it looks strange, please look down the picture . and what is a big problem that I can not use the search ! maybe I didn't compile the Doxygen sucessfully : Code:
Patching output file 5519/5533 Patching output file 5520/5533 Patching output file 5521/5533 Patching output file 5522/5533 Patching output file 5523/5533 Patching output file 5524/5533 Patching output file 5525/5533 Patching output file 5526/5533 Patching output file 5527/5533 Patching output file 5528/5533 Patching output file 5529/5533 Patching output file 5530/5533 Patching output file 5531/5533 Patching output file 5532/5533 Patching output file 5533/5533 symbol cache used 65536/65536 hits=404628441 misses=1964588 Note: based on cache misses the ideal setting for SYMBOL_CACHE_SIZE is 5 at the cost of higher memory usage. lookup cache used 65536/65536 hits=2411503 misses=201879 Note: based on cache misses the ideal setting for LOOKUP_CACHE_SIZE is 2 at the cost of higher memory usage. finished... + chmod -R a+rX ./ sxh@sxh-VirtualBox:~/foam/foam-extend-3.0/doc$ could you help me? thanks ! |
May 10, 2014, 07:20 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings bieshuxuhe,
Please provide more information, namely:
Bruno
May 10, 2014, 12:08 |
xuhe-openfoam
Rep Power: 12 |
dear Bruno ,
thanks for your reply . 1. ubuntu-12.04.4-desktop-amd64.iso 2. I download the foam-extend-3.0 installation from http://sourceforge.net/p/openfoam-ex...i/master/tree/ at April 7, 2014 . (Download Snapshot) 3. I followed http://openfoamwiki.net/index.php/In...oam-extend-3.0 to install foam-extend-3.0 installation successfully . but I get in trouble with compliling the Doxygen(source guide) of foam-extend-3.0 ! there is no installation instructions for Doxygen documentation . first , I did sudo apt-get install ( doxygen graphviz texlive-latex-base qt4-dev-tools ) . second , cd ~/foam/foam-extend-3.0/doc , and ./Allwmake ...... then ...... |
May 11, 2014, 16:42 |
Bruno Santos
Rep Power: 128 |
Hi bieshuxuhe,
I didn't have enough time this weekend to figure this out myself. All I can do is suggest that you try to use the Doxygen files from OpenFOAM 2.3, because those are more up-to-date. Or have a look into the changes made to those files from version to version of OpenFOAM. You can see it here: https://github.com/wyldckat/OpenFOAM...bo/doc/Doxygen Best regards, Bruno
extend-3.0;doxygen |
Display Modes | |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
