how to use Doxygen to generate a PDF with OpenFOAM's source code documentation?
Like Tree5Likes
  • 1 Post By wyldckat
  • 3 Post By wyldckat
  • 1 Post By elvis
Old   November 25, 2010, 09:31
Default how to use Doxygen to generate a PDF with OpenFOAM's source code documentation?
Rajshekar
Rajshekar is on a distinguished road
hi,
am new to openfoam. wanted to know how to get source code using Doxygen right
from get-install to getting source into pdf.
thanking you
Rajshekar is offline   Reply With Quote
Old   November 25, 2010, 10:21
Retired Super Moderator
Bruno Santos
Greetings Rajshekar,
For building the Doxygen documentation of OpenFOAM, you can see this post: http://www.cfd-online.com/Forums/ope...tml#post269231
If you don't want to waste time building it, you can see online in the official site www.openfoam.com under "Documentation->C++ Source Guide".
As for converting it to PDF, you'll have to see how to do it in Doxygen's website.
Best regards,
Bruno
fly_light likes this.
Old   May 25, 2014, 07:24
Freedom
wenxu is on a distinguished road
Originally Posted by Rajshekar View Post
hi,
thanking you
hi,Rajshekar. Had you got the pdf using Doxygen, I also want to get the pdf of the source code. If you have got it,please tell me how can i get it, than you in advance.
wenxu is offline   Reply With Quote
Old   May 25, 2014, 07:36
Bruno Santos
Greetings wenxu and welcome to the forum!
Using Doxygen to generate a PDF with OpenFOAM's source code, won't work well, as explained here: http://www.cfd-online.com/Forums/ope...g-doxygen.html
On the other hand, if you're looking for the PDF files for the User Guide and Programmer's Guide, have a look into the folder that is indicated by this command:
echo $WM_PROJECT_DIR/doc/Guides-a4
Best regards,
Bruno
Old   May 25, 2014, 08:03
Smile
Freedom
Best regards,
Bruno
Thank you for your prompt reply. I am a new here and i have finished the two guides, could you tell me how should i start to learn the source code of OF, i mean start from "where" or which "directory"?
Old   May 25, 2014, 08:24
Bruno Santos
My advice: don't go directly to OpenFOAM's source code, until you know what exactly you're looking for.
If you've already read the 2 Guides, then try these sources of information:
After reading/studying those pages, you should get a clearer picture of how you should approach OpenFOAM's source code.
Best regards,
Bruno
babala, stevie-tran and AnthonyP like this.
Old   May 25, 2014, 08:31
Freedom
Best regards,
Bruno
ok, thank you very much, Brun.
best regards.
wenxu
Old   June 2, 2014, 04:26
Elvis
elvis will become famous soon enough
Bruno gave you very good links to get more insight into OF!
there is also "C++ applied to OpenFOAM online course"
well the price tag is 200€
wayne14 likes this.
elvis is offline   Reply With Quote
Old   June 3, 2014, 22:33
Hu
hcs129 is on a distinguished road
Hi Bruno!
Can I see the source code in win7 system? Cause I use SSH to do my jod in win7.
Thanks in advance.
hcs129 is offline   Reply With Quote
Old   June 8, 2014, 13:55
Bruno Santos
Greetings hcs129,
See the source code? In what sense?
  1. Are you referring to the source code of OpenFOAM itself?
  2. Or are you referring to the code documentation?
Either way, the simplest solution is to simply copy the files you want to see from the remote machine to the local machine, by using WinSCP or a similar application.
The other possibility is to browse online the git repository, for example for OpenFOAM 2.3.x: https://github.com/OpenFOAM/OpenFOAM-2.3.x/
Best regards,
Bruno
Old   June 10, 2014, 03:18
Hu
Hi Bruno
I want to see source code of openfoam.For convenience,an doxygen index is desirable.
Perhaps I should install UBUNTU in my PC.Thankx!
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
