foam-extend-3.1
Hi all,
While trying to compile foam-extend-3.1 following the instruction given in doc/buildInstructions/Ubuntu/Ubuntu_14.04, most of the solvers got compliled. For dbns dolver under compressible flow, I am getting following error. Quote:
Hi Ashwani,
i've a similar problem with dbns on a sles cluster. I didn't solve it yet but i think that it has s.th. to do with the ThirdParty applications. Some of them create libraries in the usr/bin/ directory by default which needs root permission. E.g. for mesquite I tried to change the prefix as I don't have root access. It didn't help.. For you perhaps compiling ThirdParty as root helps. If you or someone else found the answer please post it as fast as possible :). Thank you, Jens |
i still didn't solve the problem. ext 3.1 works on my local suse(gcc4.8.1) machine so perhaps the compiler i use is too old (gcc 4.5.0). DId you try to update it? When I compile the src/dbns libraries I got the following error: ThirdParty/packages/ParMGridGen-1.0/platforms/linux64GccDPOpt/lib/libMGridGen.so: undefined reference to `memcpy@GLIBC_2.14' A colleague said that this also indicates a gcc problem. Hope someone can help us. Cheers, Jens |
Hey guys,
this is my last try. Does anybody know why ParMGridGen is asking for GLIBC_2.14. I successfully compiled fe31 on an CentOS 6.3 cluster where ldd --version gives ldd (GNU libc) 2.12 so 2.14 shouldn't be required (SLES System has 2.11.1). Thanks for your help! Jens |
