July 14, 2014, 11:42 |
Enable Python in paraFoam
Riccardo
Rep Power: 11 |
Hi all, I am tryng to calculate lift and drag on a cylinder, but in order to do that I need selection tools available through the Find Data dialog. When I try opening this dialog however I get this message:
Error: Find Data requires that ParaView be built with Python enabled. To enable Python set the CMake flag 'PARAVIEW_ENABLE_PYTHON' to True. What exactly am I supposed to do to enable Phyton? the installation process was harsh enough and I'd like to avoid breaking it. Thank you |
July 24, 2014, 10:34 |
Dongyue Li
Rep Power: 17 |
Hi did you solve your problem? Thanks
July 24, 2014, 10:44 |
Riccardo
Rep Power: 11 |
still no, unfortunately
November 11, 2014, 04:21 |
Dongyue Li
Rep Power: 17 |
December 14, 2014, 13:27 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Just thought I'd let you know that the latest instructions on the wiki for installing OpenFOAM 2.3.0 on Ubuntu 14.10 now include instructions to build ParaView 4.1.0 with Python and Open-MPI: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.10 I updated them on the 30th of November, but ended up forgetting to mention it here. And that the instructions for building OpenFOAM 2.3.1 are essentially the same, apart from the version number. Best regards, Bruno |
How to use python script in paraFoam? | Thomas pan | OpenFOAM Post-Processing | 0 | October 13, 2015 21:29 |
[OpenFOAM] using the python shell in paraFoam | colinB | ParaView | 14 | September 14, 2015 09:04 |
[General] Using Python in Openfoam in-built paraFoam (paraView 3.8.0) | Man Yue | ParaView | 6 | November 30, 2012 06:57 |
python scripting in paraFoam | chegdan | OpenFOAM Post-Processing | 0 | March 31, 2010 19:06 |
Python console in paraFoam. | kprzysowagmailcom | OpenFOAM Installation | 1 | August 24, 2009 07:51 |
