Error: Current directory is not $WM_THIRD_PARTY_DIR
1 Attachment(s)
Hello. Getting V. frustrated! Assume that my environment variables must be at fault but can't see what the issue is however several hours of head banging later.... :mad:
I'm a bit of a newbie at this so it's probably blindingly obvious what's wrong to those of you who know what you're doing! So. I'm attempting to compile into /opt/OpenFOAM/OpenFOAM-2.3.0 On an Ubuntu 14.04 VM. When I run ./Allwmake from the ThirdParty-2.3.0 folder I get the error: Code:
./Allwmake: 34: ./Allwmake: wmakeCheckPwd: not found Code:
root@swilley-w7:/opt/OpenFOAM/OpenFOAM-2.3.0/ThirdParty-2.3.0# echo $WM_THIRD_PARTY_DIR Any help/suggestions much appreciated! thanks Steve |
Greetings Steve and welcome to the forum!
The problem seems to be that you have more than one OpenFOAM version already installed, most likely version 2.3.x, which is why the environment variables for the other version are colliding with 2.3.0. Here is some reading material on this topic: http://openfoamwiki.net/index.php/In...with_the_Shell Best regards, Bruno |
