[foam-extend.org] Python not enabled in paraFoam foamextend3.1
Like Tree2Likes
  • 1 Post By peterk
  • 1 Post By peterk
Old   September 9, 2014, 14:42
Default Python not enabled in paraFoam foamextend3.1
Peter Knapen
peterk is on a distinguished road
Hello ,
I have problems getting information from ParaView.
I have installed ParaView in foam-extend3.1 in Ubuntu 14.04TS, using AllMake.stage4 in ThirdParty directory.
When I try to read data from the display (find data via scalar value (v)), I get the error message: p, li { white-space: pre-wrap; } error: Find Data requires that ParaView be built with Python enabled. To enable Python set the CMake flag 'PARAVIEW_ENABLE_PYTHON' to True.
As AllMake.stage4 does not mention this flag, I do not know how to fix this.
Best regards,
Peter
peterk is offline   Reply With Quote
Old   September 9, 2014, 15:14
Peter Knapen
I thouhgt I found the answer:
(http://www.cfd-online.com/Forums/ope...w-3-8-1-a.html)
but Allmake.stage4 (after running AllClean.stage4) is ready within a second, without error message, but I still can not use the button
Besat regards,
Peter
Old   January 18, 2015, 09:09
Retired Super Moderator
Bruno Santos
Greetings Peter,
I've had this on my to-do list for quite sometime now and I finally managed to look into this today. It seems that the following patch can solve this issue:
diff --git a/ThirdParty/AllMake.stage4 b/ThirdParty/AllMake.stage4
index 6a3409b..463ed91 100755
--- a/ThirdParty/AllMake.stage4
+++ b/ThirdParty/AllMake.stage4
@@ -74,7 +74,7 @@ then
     if [ -d "$QT_BIN_DIR" -a -r "$QT_BIN_DIR"/qmake ]
     then
         ( rpm_make -p ParaView-4.0.1 -s ParaView-4.0.1.spec -u http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/ParaView-v4.0.1-source.tgz \
-            -f --define='_qmakePath $QT_BIN_DIR/qmake'
+            -f --define '_qmakePath $QT_BIN_DIR/qmake'  --define '_withPython true' --define '_pythonLibPath /usr/lib/libpython2.7.so.1.0'
     else
         echo "WARNING: "
diff --git a/ThirdParty/rpmBuild/SPECS/ParaView-4.0.1.spec b/ThirdParty/rpmBuild/SPECS/ParaView-4.0.1.spec
index aec695b..d8f2fcc 100644
--- a/ThirdParty/rpmBuild/SPECS/ParaView-4.0.1.spec
+++ b/ThirdParty/rpmBuild/SPECS/ParaView-4.0.1.spec
@@ -163,6 +162,69 @@ Patch0:                 ParaView-4.0.1.patch_darwin
     # Add the value of _qmakePath for QT_QMAKE_EXECUTABLE
     addCMakeVariable  QT_QMAKE_EXECUTABLE:FILEPATH=%{_qmakePath}
+if [ "%{_withPython}" = "true" ]; then
+    if pythonBin=$(which python 2>/dev/null)
+    then
+        if [ -n "%{_pythonLibPath}" ]
+        then
+            # check %{_pythonLibPath} if it has been set
+            if [ ! -e "%{_pythonLibPath}" ]
+            then
+                echo "*** Error: libpython not found at location specified " \
+                     "by -pythnon-lib input: PYTHON_LIBRARY=%{_pythonLibPath}"
+            fi
+        else
+            # Try to get %{_pythonLibPath} from dynamically linked binary
+            PYTHON_LIBRARY=$(ldd $pythonBin | \
+                sed -ne '/libpython/s/.* => \(.*\) (.*/\1/p')
+           [ -e "%{_pythonLibPath}" ] || {
+               echo "*** Error: Unable to determine path to python library."
+        fi
+            echo "    Please set the full path to the python library "
+            echo "    (including libpython) using the -python-lib option, "
+            echo "    or deactivate python support by not using the -python "
+            echo "    option"
+            exit 1
+        pythonMajor=$(echo %{_pythonLibPath} | sed 's/.*libpython\(.*\)\.so.*/\1/')
+        pythonInclude=/usr/include/python$pythonMajor
+        # note - we could also allow for a PYTHON_INCLUDE variable ...
+        [ -d "$pythonInclude" ] || {
+            echo "    No python headers found in $pythonInclude/"
+            echo "    Please install python headers or deactivate "
+            echo "    python support by not using the -python option"
+            exit 1
+        addCMakeVariable  "PARAVIEW_ENABLE_PYTHON=ON"
+        addCMakeVariable  "PYTHON_INCLUDE_PATH=$pythonInclude"
+        addCMakeVariable  "PYTHON_LIBRARY=%{_pythonLibPath}"
+        echo "----"
+        echo "Python information:"
+        echo "    executable     : $pythonBin"
+        echo "    version        : $pythonMajor"
+        echo "    include path   : $pythonInclude"
+        echo "    library        : %{_pythonLibPath}"
+        unset pythonBin pythonInclude pythonMajor
+    else
+        echo "*** Error: python not found"
+        echo "***        Deactivate python support by not using the -python "
+        echo "***        option"
+        exit 1
+    fi
+fi
     echo "CMAKE_VARIABLES: $CMAKE_VARIABLES"
     mkdir -p ./buildObj
edit 1: Uhm... apparently this didn't work... I failed to see the need for "-f"... will edit back in a few minutes...
edit 2: OK, fixed the patch provided above. It should now work as intended, once this patch is applied.
edit 3: Oh for crying out loud... the option is not plugged in to anything... didn't work yet.
edit 4: OK, full patch is now in the code box above. I'm still testing this, but it should finally work as intended .
Note: The path "/usr/lib/libpython2.7.so.1.0" is the one I have for Ubuntu 12.04. Other library paths for other Ubuntu versions are available here: http://openfoamwiki.net/index.php/In...M-2.3.1/Ubuntu
edit 5: Confirmed. The latest patch in the code block above fixes the problem.
Best regards,
Bruno
Old   January 18, 2015, 14:32
Peter Knapen
Hello Bruno,
Thanks for looking into this, however I now have the problem that AllClean.stage4 does not recognize the installed paraView version, so it is not uninstalled.
On another computer I have uninstalled ParaView via the Ubuntu Software Centre, when I then apply the AllMake.stage4, I get problems with unpacking of the archive: cpio mkdir failed - Permission denied
error ParaView-4.0.1-linux64GccDPOpt.x86_64: install failed
Done installing package.
Best regards
Peter
Old   January 18, 2015, 14:49
Bruno Santos
Hi Peter,
Uhm... I'm flying blind here... please describe in more detail how and where you've installed foam-extend 3.1, as well as what prerequisites you've installed, because it seems that you're using a less conventional installation than usual.
Best regards,
Bruno
Old   January 19, 2015, 14:46
Peter Knapen
Hello Bruno,
I don't know the details anymore. I deleted foamextend-3.1 and will reinstall it once again. Will keep you posted tomorrow or the day after.
Best regards,
Peter
Old   January 20, 2015, 06:43
Default new installation of foamextend-3.1
Peter Knapen
Hello Bruno,
I have re-installed foamextend-3.1 using git from :
http://sourceforge.net/p/openfoam-ex...u/Ubuntu_14.04
Using paraFoam I get some errors on fonts.I don't know where they are comming from :
pk28831@sys7:~/foam/pk28831-3.1/run/droptest/solid$ paraFoam
created temporary 'solid.OpenFOAM'
Fontconfig warning: "/etc/fonts/conf.d/65-ttf-sil-andika.conf", line 14: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/etc/fonts/conf.d/65-ttf-sil-andika.conf", line 32: Having multiple <family> in <alias> isn't supported and may not work as expected
Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed!
I am not able to delete ParaView with AllClean.stage4:
Then AllMake.stage4 (adapted according to your patch) does not change anything, see below:
pk28831@sys7:~/foam/foam-extend-3.1/ThirdParty$ ./AllClean.stage4
This system rpm command: rpm --force-debian
Starting ThirdParty AllClean: Stage4
Removing qt-everywhere-opensource-src-4.7.4
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/qt-everywhere-opensource-src-4.7.4*.rpm
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/SOURCES/qt-everywhere-opensource-src-4.7.4.tar.gz
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/TGZS/x86_64/qt-everywhere-opensource-src-4.7.4.tgz
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4*
Add option alsoPackage to remove the installed files.
Removing ParaView-3.12.0
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.12.0*.rpm
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/SOURCES/ParaView-3.12.0.tar.gz
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/TGZS/x86_64/ParaView-3.12.0.tgz
Not found: /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/BUILD/ParaView-3.12.0*
Done ThirdParty AllClean: Stage4
pk28831@sys7:~/foam/foam-extend-3.1/ThirdParty$ cp ~/AllMake.stage4 .
pk28831@sys7:~/foam/foam-extend-3.1/ThirdParty$ ./AllMake.stage4
Starting ThirdParty AllMake: Stage4
Using system installed QT
Package name      : ParaView-4.0.1
Package URL       : http://downloads.sourceforge.net/pro...0.1-source.tgz
RPM spec file name: ParaView-4.0.1.spec
Additional flags  : --define
Updating the ThirdParty environment variables before building package ParaView-4.0.1
RPM file name     : /home/pk28831/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm
Package ParaView-4.0.1 is already installed
Done ThirdParty AllMake: Stage4
I have tried with the previous installation to adapt AllMakeClean.stage4, in order to remove version 4 of ParaView, the file ran, but PAraView was still installed.
So far the findings with the new installation.
Best regards,
Peter
Old   January 24, 2015, 13:15
Bruno Santos
Hi Peter,
OK, the AllClean.stage4 script apparently is very outdated. Nothing like fixing the problem with one's own hands:
foam3rdParty
rm rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm
rm -r packages/ParaView-4.0.1/
And you should now be good to run the AllMake script!
In addition, my apologies, but I was so disoriented with not fixing the problem at my first couple of tries, that I ended up not uploading a tarball with the files that were modified. You can find them now in attachment, namely in "modified_files.tar.gz". Unpack it in the "ThirdParty" folder:
foam3rdParty
tar -xzf /path/to/modified_files.tar.gz
Best regards,
Bruno
Old   January 25, 2015, 10:13
Peter Knapen
Hello Bruno,
Sorry for keeping you busy, but first I got the error that the path to libpython2.7.so.1.0 was not found on /usr/lib.
I corrected this by the following command:
sudo ln -s  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 /usr/lib/libpython2.7.so.1.0
When I ran AllMake.stage4 (the new one) after AllClean.stage4, the compilation stopped with following error (at 3%):
[  3%] Building CXX object ThirdParty/QtTesting/vtkqttesting/CMakeFiles/QtTesting.dir/moc_pqThreadedEventSource.cxx.o
[  3%] Building CXX object ThirdParty/QtTesting/vtkqttesting/CMakeFiles/QtTesting.dir/moc_pqTimer.cxx.o
[  3%] Building CXX object ThirdParty/QtTesting/vtkqttesting/CMakeFiles/QtTesting.dir/moc_pqTreeViewEventPlayer.cxx.o
[  3%] Building CXX object ThirdParty/QtTesting/vtkqttesting/CMakeFiles/QtTesting.dir/moc_pqTreeViewEventTranslator.cxx.o
[  3%] Building CXX object ThirdParty/QtTesting/vtkqttesting/CMakeFiles/QtTesting.dir/moc_pqWidgetEventTranslator.cxx.o
Linking CXX shared library ../../../lib/libQtTesting.so
[  3%] Built target QtTesting
Linking C shared library ../../../../lib/libvtklibxml2-pv4.0.so
[  3%] Built target vtklibxml2
make: *** [all] Error 2
error: Bad exit status from /home/peterk/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.bC2bmr (%build)
RPM build errors:
Installing package: ParaView-4.0.1
  Uninstalling ParaView-4.0.1 using RPM: ParaView-4.0.1-linux64GccDPOpt.x86_64
  Installing ParaView-4.0.1 using RPM file: /home/peterk/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm
error: open of /home/peterk/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm failed: No such file or directory
This is done on a new installation of Ubuntu14.04LTS:
7 3.13.0-44-generic #73-Ubuntu SMP Tue Dec 16 00:22:43 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Best regards,
Peter
Old   January 25, 2015, 10:35
Bruno Santos
Hi Peter,
Ooops, sorry, I had only tested on Ubuntu 12.04. The symbolic link you've done does fix the initial problem, but you could have edited the file "AllMake.stage4" and fix said path
Please install the packages indicated here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.10 - in step #2. Those are, as far as I know, all of the necessary packages needed to build ParaView with Python support.
Best regards,
Bruno
Old   January 25, 2015, 13:12
Peter Knapen
Hello Bruno,
Strange, but these are different packages than described on the wikipage for installing (there a space was missing between the packages, I have made a tag for this).
I have installed all the packages mentioned under 2, including that for CGAL.
Now is goes wrong on another line in make:
error: Bad exit status from /home/peterk/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.K9NOZZ (%build)
RPM build errors:
Best regards,
Peter
Old   January 25, 2015, 13:38
Bruno Santos
Hi Peter,
Can you please attach the full output log file "log.make"?
./AllMake.stage4 > log.make 2>&1
You can compress it with tar or gzip:
  • Code:
    gzip log.make
    Results in "log.make.gz".
  • Code:
    tar -czf log.make.tar.gz log.make
    Results in "log.make.tar.gz".
Best regards,
Bruno
Old   January 25, 2015, 13:41
Peter Knapen
Hello Bruno,
In a way we are now adding packages needed by OpenFoam2.3.1 to the ones as needed by foam-extend3.1. Can't this be a problem?
I can tomorrow try it on another computer, the one I tried today is a laptop.
Best regards,
Peter
Old   January 25, 2015, 13:45
Bruno Santos
The installation instructions currently available for foam-extend 3.1 are only meant for a fixed set of features.
As you've seen, we're trying to build new features that foam-extend 3.1 is not yet prepared to handle, which is why the modifications were necessary. On the other hand, I know from my own experience that those latest instructions for OpenFOAM 2.3.1 for Ubuntu 14.10 are able for certain to build ParaView with Python and so on. Which is why I requested that you'd install those packages.
My rough guess is that the problem your having right now is hidden somewhere above the output you've shown, which is why I was asking for the full log file. Specially because I don't have enough time to test this on Ubuntu 14.04 with foam-extend 3.1 and so on
Old   January 25, 2015, 13:50
Peter Knapen
Hello Bruno,
see the attached file, now only reaching 3% again, so I am afraid it could also be something in the hardware of the laptop
Old   January 25, 2015, 14:04
Bruno Santos
Ah HA! My intuition was right
Several lines above the final end you looked at, this can be found:
xmlpatterns: could not exec '/usr/lib/x86_64-linux-gnu/qt5/bin/xmlpatterns': No such file or directory
The solution is simple and is also already explained in the instructions for OpenFOAM 2.3.1: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.10 - Simply run:
export QT_SELECT=qt4
Hopefully this fixes the problem
Old   January 25, 2015, 15:47
Peter Knapen
Helllo Bruno,
Thanks for all the effort, the compilation succeeded, but I have still to set somewhere the envronment variable to paraview: if I run a tutorial and start paraFoam, I get the error that paraview is not found, the command is there in :
~/foam/foam-extend-3.1/ThirdParty/packages/ParaView-4.0.1/platforms/linux64GccDPOpt/bin .
This is the result of running the tutorial:
electrostaticFoam  mhdFoam
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics$ cd mhdFoam/
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam$ ls
Allclean  Allrun  hartmann
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam$ ./Allrun
Running blockMesh on /home/peterk/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann
Running mhdFoam on /home/peterk/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann
Running foamCalc on /home/peterk/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann
Running sample on /home/peterk/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam$ cd hartmann/
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann$ ls
0  0.5  1  1.5  2  constant  log.blockMesh  log.foamCalc  log.mhdFoam  log.sample  sets  system
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann$ paraFoam
created temporary 'hartmann.OpenFOAM'
/home/peterk/foam/foam-extend-3.1/bin/paraFoam: line 142: paraview: command not found
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann$ vi /home/peterk/foam/foam-extend-3.1/bin/paraFoam
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann$ which paraView
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann$ paraView
No command 'paraView' found, did you mean:
 Command 'paraview' from package 'paraview' (universe)
paraView: command not found
peterk@TNR3427:~/foam/peterk-3.1/run/tutorials/electromagnetics/mhdFoam/hartmann$ paraview
The program 'paraview' is currently not installed. You can install it by typing:
sudo apt-get install paraview
Once again, thanks for your time, here in Holland it is now 21:45 hrs.
Best regards,
Peter
Old   January 25, 2015, 16:26
Bruno Santos
Hi Peter,
Try starting a new terminal window, so that the shell environment is guaranteed to be updated.
And confirm if the following commands work as intended:
echo $PARAVIEW_BIN_DIR
echo $PARAVIEW_DIR
echo $PARAVIEW_INCLUDE_DIR
echo $PARAVIEW_LIB_DIR
which paraview
They should give something like this:
$ echo $PARAVIEW_BIN_DIR
/home/ofuser/foam/foam-extend-3.1/ThirdParty/packages/ParaView-4.0.1/platforms/linux64GccDPOpt/bin
$ echo $PARAVIEW_DIR
$ echo $PARAVIEW_INCLUDE_DIR
/home/ofuser/foam/foam-extend-3.1/ThirdParty/packages/ParaView-4.0.1/platforms/linux64GccDPOpt/include/paraview-4.0
$ echo $PARAVIEW_LIB_DIR
/home/ofuser/foam/foam-extend-3.1/ThirdParty/packages/ParaView-4.0.1/platforms/linux64GccDPOpt/lib
$ which paraview
/home/ofuser/foam/foam-extend-3.1/ThirdParty/packages/ParaView-4.0.1/platforms/linux64GccDPOpt/bin/paraview
Best regards,
Bruno
Old   January 25, 2015, 16:38
Peter Knapen
Hello Bruno,
When I just add the complete path to paraview in the paraFoam file, then paraFoam starts and I the python is enabled, so I am still searching which environment variable has to be set. I can find it that quickly via google and the forum.
Best regards and goonight,
Peter
wyldckat likes this.
Old   January 25, 2015, 16:48
Peter Knapen
Hello Bruno,
This is the second time today, that our postings crossed in time.
I have removed the path in paraFoam. In a new terminal the environment variables are now ok.
starting paraFoam in the new terminal works well,
I only remember from the past that paraView opened directly supposing a OpenFoam file had to be read, now it opens with a menue of which one is openFoam.
Thanks once again for the effort: everything is working now
[OpenFOAM] How to use python script in paraFoam? Thomas pan ParaView 0 October 12, 2015 04:34
[OpenFOAM] using the python shell in paraFoam colinB ParaView 14 September 14, 2015 09:04
[Other] Enable Python in paraFoam tabsquare OpenFOAM Installation 4 December 14, 2014 13:27
[General] Using Python in Openfoam in-built paraFoam (paraView 3.8.0) Man Yue ParaView 6 November 30, 2012 06:57
python scripting in paraFoam chegdan OpenFOAM Post-Processing 0 March 31, 2010 19:06
