OpenFOAM installation on Slackware Linux
Dear all,
I am very new to Linux and OpenFOAM. So, I am stuck at installation of OpenFoam on Slackware. Somebody, Kindly guide through a step by step installation procedure. Thanks |
there is a wiki http://openfoamwiki.net/index.php/Ca...nFOAM_on_Linux unfortunately Slackware did not get a Help page, only the usual suspects Ubuntu/Debian, Rad Hat, CentOs etc. |
Thanks elvis, for the info...So, is there anyone who can help me out?
I hope there might be someone who can actually help me with the installation. can you help me? |
Greetings to all!
@Mehar: If you're new to Linux, why did you choose Slackware Linux? As Elvis indicated, instructions are already available for several Linux Distributions, usually for the most popular ones. If you install one of those distributions, you will more easily install OpenFOAM in it. Therefore, if you're using Slackware, can you please give us a good reason as to why you're using that distribution? I ask this because it takes considerable time to test and write installation instructions for each Linux Distribution, therefore I honestly would like a good reason as to why I or anyone else should take the time to do try/use Slackware? Best regards, Bruno |
Hello Mehar,
I did not know much about linux either, when started using Slackware. I like to do things the hard way :). So, do not be discouraged by that. If you come to master it, it is very rewarding. But it is quite hard, and you have to read/learn a lot, by yourself. www.google.COM is your friend. You will find all the answers you need, if you ask it nicely. OpenFOAM install on a stock Slackware is straightforward, one just needs to follow by letter, the installation instructions on http://www.openfoam.com/; it is that easy. However, I will paste here, the commands to install the 2.3.x repository release (on Slackware 14.1, 64 bit). Run the commands as user "mehar", or whatever user you have. I recommend that while you run these commands, you keep an eye, or, maybe both :) on http://www.openfoam.org/download/git.php and identify the steps where you need to check whether all is in order. The log.Allwmake file could be useful for identifying the errors in a failed build. Code:
mkdir /home/mehar/OpenFOAM Best regards, Ervin |
Please feel free to add this and future information about these packages for Slackware at https://openfoamwiki.net/index.php/Installation/Linux |
