[Other] Jetson TK1 supercomputer dev board
Old   November 20, 2014, 03:32
Default Jetson TK1 supercomputer dev board
Mike Hersee
MikeHersee is on a distinguished road
Hi Folks,
Is anyone experimenting with installing openfoam on the Jetson TK1 development board? The reason I ask is because with 192 cores, even if it has some limitations being a development board, at on £199 from Maplin in the UK and less in dollars in the US, it offers apparently very low power supercomputing at a ridiculously low price also. Given that CFD is intrinsically such a massively computationally intensive operation, this seems to me like a no-brainer - to attempt at least.
Anyone?
Mike Hersee
MikeHersee is offline   Reply With Quote
Old   November 23, 2014, 12:28
Retired Super Moderator
Bruno Santos
Greetings Mike Hersee,
From what I can see, that board is using NVidia's Tegra K1 chip, which is essentially an ARM CPU with integrated GPU. This means that you'll need to merge two compiling characteristics:
Beyond this, I'm not sure that such a machine is all that better, at least performance-wise. For conceptual development, it might be a good way to get started on this topic, since it's an ITX board with GPU integrated, which means that it costs less than half of a good x86 development machine with a dedicated GPU card.
The other detail is that this board would have to rely on 1Gbps Ethernet connection only or at least on some sort of hybrid Ethernet-USB 3.0 based network... in case multiple boards were to be used in parallel.
Best regards,
Bruno
Old   November 25, 2014, 16:53
Mike Hersee
Ok, thanks for that analysis. I think it's probably way beyond where I'm at technically with Linux right now though, but I'm a bit disappointed that it doesn't sound as though it would perform as spectacularly as I'd hoped it would.
Mike
Parallella & Jetson TK1 wgvanveen SU2 1 January 1, 2015 19:35
Temperature Distribution on a circuit board Blackadder Main CFD Forum 1 March 27, 2003 11:32
