November 20, 2014, 03:32 |
Jetson TK1 supercomputer dev board
Mike Hersee
Rep Power: 11 |
Hi Folks,
Is anyone experimenting with installing openfoam on the Jetson TK1 development board? The reason I ask is because with 192 cores, even if it has some limitations being a development board, at on £199 from Maplin in the UK and less in dollars in the US, it offers apparently very low power supercomputing at a ridiculously low price also. Given that CFD is intrinsically such a massively computationally intensive operation, this seems to me like a no-brainer - to attempt at least. Anyone? Mike Hersee |
November 23, 2014, 12:28 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Mike Hersee,
From what I can see, that board is using NVidia's Tegra K1 chip, which is essentially an ARM CPU with integrated GPU. This means that you'll need to merge two compiling characteristics:
The other detail is that this board would have to rely on 1Gbps Ethernet connection only or at least on some sort of hybrid Ethernet-USB 3.0 based network... in case multiple boards were to be used in parallel. Best regards, Bruno |
November 25, 2014, 16:53 |
Mike Hersee
Rep Power: 11 |
Ok, thanks for that analysis. I think it's probably way beyond where I'm at technically with Linux right now though, but I'm a bit disappointed that it doesn't sound as though it would perform as spectacularly as I'd hoped it would.
Mike |
Parallella & Jetson TK1 | wgvanveen | SU2 | 1 | January 1, 2015 19:35 |
Temperature Distribution on a circuit board | Blackadder | Main CFD Forum | 1 | March 27, 2003 11:32 |
