OF-2.3.1 included in OF-2.3.x ?
Dear All
I use OpenFOAM-2.3.x compiled from git. Now OpenFOAM-2.3.1 was released. Do you think I should download 2.3.1 and compile again? or my current installation (2.3.x) can be upgraded to 2.3.1 with "git pull" and compile again.... thank you |
Absolutely. 2.3.1 is covered in 2.3.x so if you
git pull |
Thank you Dan,
yes I have working with 2.3.x now. How about ThirdParty-2.3.1? Currently I use the ThirdParty-2.3.0. Should I compile ThirdParty-2.3.1 ? |
Nope, should work fine....or it does with my current version of Thirdparty. Just make sure that your WM_THIRD_PARTY_DIR uses the correct WM_PROJECT_VERSION in your OpenFOAM-2.3.x/etc/bashrc file.
FYI: The only difference between ThirdParty 2.3.0 and 2.3.1:
