[OpenFOAM.org] Installation issue - CGAL/Delaunay_triangulation_3.h
Like Tree6Likes
  • 1 Post By wyldckat
  • 2 Post By wyldckat
  • 1 Post By lost.identity
Old   January 29, 2015, 11:42
Unhappy Installation issue - CGAL/Delaunay_triangulation_3.h
lost.identity is on a distinguished road
I'm trying to install OpenFOAM 2.3.1 on SUSE Linux Enterprise Server 11 SP3. I'm following the instructions on
http://openfoamwiki.net/index.php/In...#openSUSE_12.3
After some difficulty I've managed to build the ThirdParty folder without any errors. However, now when I try to compile the main OpenFOAM folder I get the following error
fata error: CGAL/Delaunay_triangulation_3.h: No such file or directory
I've had a look at the following thread to find out any answers
http://www.cfd-online.com/Forums/ope...myhexmesh.html
However, the difference to that thread is, I am able to compile CGAL library in the ThirdParty folder without any issues. I think my culprit might be cmake. My machine only has cmake-2.6 installed. However, I used the following explanation: https://forums.suse.com/showthread.p...ools-libraries, to install cmake version 2.8.12.2 and use it as a prefix as in
PATH="${HOME}/opt/cmake_2.8.12.2/bin/:${PATH}" ./Allwmake
Any ideas what might be going wrong?
Thanks!
lost.identity is offline   Reply With Quote
Old   January 29, 2015, 17:03
Retired Super Moderator
Bruno Santos
Greetings lost.identity,
If you're trying to build OpenFOAM 2.3.1, then please follow these instructions: http://openfoamwiki.net/index.php/In...#openSUSE_12.3 - and not the ones meant for OpenFOAM 2.3.0
As indicated in step #10, please follow the instructions therein:
#Create a tarball in case you've seen any errors (it's the first error that matters)
#or if you don't understand the output
#and attach the file "make.log.tar.gz" to a post in the designated thread
tar -czf make.log.tar.gz make.log
In addition, please indicate what the following commands give you:
cmake --version
echo $CMAKE_ROOT
Best regards,
Bruno
Old   January 30, 2015, 06:35
Hi Bruno,
Thanks for your reply. I ran Allclean in my ThirdParty folder before re-doing the installation again.
Now there are few hiccups on the way, mainly because I'm using the SUSE Enterprise and not openSUSE. I'll list them down here.
1) I think the equivalent pattern to devel_C_C++ in SLES is sdk_c_c++ so I installed that. Secondly, qt4-assistant-adp-devel, doesn't exist in any SDK repositories so it is no installed.
2) I do not have the correct versions of gmp, mpfr, mpc and gcc. Therefore, following this thread
http://www.cfd-online.com/Forums/ope...n-problem.html
I downloaded the right versions of these software into my ThirdParty directory and extracted there. Then I first ran makeGcc.
3) I do not have a recent version of cmake.
cmake --version
cmake version 2.6-patch 2
That's the output from my cmake. So as I mentioned before I installed cmake-2.8.12.2 and then used the following to compile
I did not get any errors yesterday when I did this. But today I saw the following error
cp: cannot stat `../bin/d[agm]*': No such file or directory
make: [install] Error 1 (ignored)
But I'm ignoring that error and there are no further errors in the ThirdParty make.
4) I still see the same issue again when I try to compile main OpenFOAM directory. I've attached the compressed log file.
Thanks.
Old   January 31, 2015, 06:21
Bruno Santos
Hi lost.identity,
Just in case, please check which version of make you're using:
make --version
As for a possible fix, the following steps are based on these: http://openfoamwiki.net/index.php/In...EL#CentOS_5.10
  1. The "Boost" library/toolbox in your system also seems to be considerably old. Therefore, let's get a more recent one:
    foam
    sed -i -e 's=boost-system=boost_1_54_0=' etc/config/CGAL.sh
    cd $WM_THIRD_PARTY_DIR
    alias wget="wget --no-check-certificate"
    wget "https://raw.github.com/wyldckat/scripts4OpenFOAM3rdParty/master/getBoost"
    chmod +x getBoost
    ./getBoost
    sed -i -e 's=boost-system=boost_1_54_0=' makeCGAL
  2. Now try building only CGAL:
    ./makeCGAL > mkcgal.log 2>&1
  3. Check the contents of the file "mkcgal.log" and check if there exists an error message at the end and if it's as cryptic at the one you've gotten so far or not:
    == Generating build files (DONE) ==
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/flacs/OpenFOAM/ThirdParty-2.3.1/CGAL-4.3
    + make -j 8
    make: *** No targets specified and no makefile found.  Stop.
    + exit 1
Best regards,
Bruno
lost.identity likes this.
Old   January 31, 2015, 09:56
Hi Bruno,
Thanks again for your reply. This is the output for make --version
make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for x86_64-unknown-linux-gnu
The machine I'm trying to install the OpenFOAM does not have internet access, but I've downloaded boost tar file from another machine and copied it to the ThirdParty folder and tried to follow the instructions as close as possible.
if I run ./makeCGAL on it's own I get the following error (my guess it's not using the correct cmake)
CMake Error: Error in cmake code at
/home/flacs/OpenFOAM/ThirdParty-2.3.1/CGAL-4.3/cmake/modules/CGAL_Macros.cmake:213:
Parse error.  Function missing ending ")".  Instead found left paren with text "(".
CMake Error at CMakeLists.txt:340 (include):
  include could not find load file:
CMake Error at CMakeLists.txt:341 (cgal_setup_module_path):
  Unknown CMake command "cgal_setup_module_path".
-- Configuring incomplete, errors occurred!
+ exit 1
In fact the only way I could compile anything is if I prefix the installation as
PATH="${HOME}/opt/cmake_2.8.12.2/bin/:${PATH}" ./makeCGAL
The above compilation does not give any errors. Is there a way to somehow to make the system always take cmake-2.8.12.2 rather than cmake-2.6.2?
Thanks
Old   January 31, 2015, 10:39
Bruno Santos
Hi lost.identity,
Run the following commands:
mkdir -p $WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER
ln -s ${HOME}/opt/cmake_2.8.12.2 $WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/cmake-2.8.12.1
it creates a symbolic link for the folder where OpenFOAM expects to find the latest CMake version installed.
Start a new terminal and it should be fully operational!
Best regards,
Bruno
lost.identity and jfolio like this.
Old   January 31, 2015, 12:41
Hi Bruno,
When I created a symbolic link CGAL worked. However, I still had the same issue with the main OpenFOAM compilation.
So I did a Allclean and then tried to install everything again. However, now even though I followed the same steps I get the same
+ exit 1
Even though the symbolic link is there. I tried it on another system (with identical setup) and it still doesn't work
EDIT: I had to run makeCmake in ThirdParty directory to get it to work. I don't understand it.
Anyways I'm able to run makeCGAL and Allwmake in ThirdParty directory without any issues. The issue with CGAL/Delaunay_triangulation_3.h still remains.
jfolio likes this.
Old   January 31, 2015, 13:16
Bruno Santos
Remember when I wrote in the other post that I had based my commands on this wiki page: http://openfoamwiki.net/index.php/In...EL#CentOS_5.10
Well... on that page there are a lot of instructions that might come in handy for your installation!
If my diagnosis is correct, the clean up you've done removed the symbolic link, which is why CMake stopped behaving properly. In addition, when you ran makeCmake, you either didn't start a new terminal or did not run this command:
wmSET $FOAM_SETTINGS
see step #10 to see what I mean
If this fails, then honestly, my suggestion is that you start a new OpenFOAM installation (you can simply rename the current folders, just in case you prefer to go back to where you once were) and then you can roughly follow those instructions that are meant for CentOS 5.10 on your system, because SLES 11 should be about as old as CentOS 5
I say this, because those steps have been carefully tailored and tested (by me) to have all of the necessary steps to have a fully working build of OpenFOAM, along with ParaView.
Nonetheless, if you do not want to start over, then try to study a bit more those instructions, to see if you can spot what you might be missing so far...
Old   January 31, 2015, 14:25
Many thanks Bruno.
I downloaded the source code again and started from scratch and now it works. I had to basically download mpfr, mpc, gmp, gcc, Qt, cmake as my machine didn't have the correct versions. Then compiled them in the ThirdParty directory.
I also had to make sure that the make files had the correct version numbers (had to modify etc/config/settings.sh in the OpenFOAM directory).
wyldckat likes this.
Old   December 15, 2016, 08:41
Default no targets specified
rahulksoni's Avatar
Rahul Kumar Soni
rahulksoni is on a distinguished road
Send a message via Skype™ to rahulksoni
Originally Posted by wyldckat View Post
Hi lost.identity,
make --version
    foam
    chmod +x getBoost
    ./getBoost
    -- Configuring done
    -- Generating done
    + make -j 8
    + exit 1
Best regards,
Bruno
Hi Bruno
I am getting similar error
+ make -j 8
+ exit 1
What is causing that error?
rahulksoni is offline   Reply With Quote
Old   December 15, 2016, 09:10
Cool Got it
  #11
rahulksoni's Avatar
Rahul Kumar Soni
Originally Posted by rahulksoni View Post
Hi Bruno
+ make -j 8
+ exit 1
Got it surprisingly if I go to ThirdParty-2.3.0/CGAL-4.3 and then execute make and make install then it works.
I also tried it by forcing to go to CGAL directory and then run make and make install in makeCGAL file. It works
$CGAL_SOURCE_DIR \
&& cd $CGAL_SOURCE_DIR \
&& make -j $WM_NCOMPPROCS \
&& make install || exit 1 \
&& cd ..
Its peculiar why it is not entering the source directory and executing the commands!!!
[OpenFOAM.com] Multiple Installation Issue: Parallel Processing No Longer Works dancfd OpenFOAM Installation 11 November 20, 2018 17:08
Convergence issue in natural convection problem chrisf90 FLUENT 5 March 5, 2016 09:30
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 09:27
Installation problems indy OpenFOAM Installation 7 April 3, 2009 10:40
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
