Trying to install foam-extend 3.1 on Ubuntu 14.04
Running Ubuntu 14.04 LTS and following instructions detailed here.
When I source the bash with Code:
foam-extend-3.1$ . etc/bashrc Code:
bash: /opt/foam-extend-3.1/bin/foamGetSystemInfo: No such file or directory Code:
foamInstall=$HOME/$WM_PROJECT I also have OpenFOAM installed, could this be an issue? I'm wondering whether I should remove it anyway. Are there any features in OpenFOAM that aren't in OpenFOAM extension? |
You have got OpenFOAM installed and seems to set up environment for it, that is why foam-extend is trying to look into /opt. Before ". etc/bashrc" issue "wmUNSET" command. |
Some other conflicts I've found today is that paraFoam doesn't really work with the new foam extend case files but it also does not work as intended in previously functioning OpenFOAM case files. I'm working around this at the moment by just doing Code:
$ touch anything.foam |
