Complete removal and reinstallation issues
Hi OpenFOAM users,
This is my first post and I am fairly new to OpenFOAM so I will try to be clear and concise with my problem: I recently upgraded my laptop to a MacbookPro with VirtualBox to run Ubuntu 12.04. I thought I would give OpF v2.3.0 a go. After installation I attempted to compile one of my solvers and ran into a problem with the IObasicSourceList.H. After following a few threads with no luck I decided I would go back to OpF v2.1.1 knowing that my solvers should be able to compile as is. Without uninstalling v2.3.0 I installed v2.1.1, because I had read that it wasn't a problem to have two versions running. While following all installation steps I ran into problems when running the command: Code:
mkdir -p $FOAM_RUN Code:
mkdir: missing operand I fear I may have accidentally removed something important in the process. I haven't been able to find a similar problem while trolling these threads. So I hope someone might be able to help walk me through it. Many thanks in advance, Rachael |
Greetings Rachael and welcome to posting on this forum!
Fortunately, most of the solutions for your questions are already answered on the wiki:
Beyond this, I would need to know how exactly you installed each version, namely which installation instructions you followed. Best regards, Bruno |
My guess is that you are not properly sourcing the environmental variables in your .bashrc. If you installed from the deb pack, try
source /opt/openfoam231/etc/bashrc |
