[OpenFOAM.org] bash: /opt/openfoam230/etc/bashrc: No such file or directory |
July 6, 2015, 19:29 |
samira
Rep Power: 11 |
Dear all,
I wanted to install new version python ,I googled how to install python And I opened this page http://askubuntu.com/questions/10159...-7-2-on-ubuntu I writed in terminal sudo apt-get install build-essential checkinstall sudo apt-get install libreadline-gplv2-dev libncursesw5-dev libssl-dev libsqlite3-dev tk-dev libgdbm-dev libc6-dev libbz2-dev so I'm thinking of completely remove all the content of 2.3.0 (((((( when I open terminal window,it says: bash: /opt/openfoam230/etc/bashrc: No such file or directory please please help me :| Any suggestions would be appreciated. |
July 7, 2015, 12:31 |
Ashwani
Rep Power: 12 |
Can you check your bashrc file in home directory using gedit/$HOME/.bashrc . It might have this line, which is used for sourcing the OpenFOAM. This would have come when you have installed OpenFOAM via root. If it is there you can comment this line, in this file. And the try. Hope it helps.
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
