OpenFOAM-2.3.x Building CGAL Every Compile
I just pulled the most recent version of OF-2.3.x from the git repo and now CGAL is rebuilding every time that I invoke Allwmake. This never occurred before so I don't exactly know what is going on. Anyone else experiencing this same issue?
Quick answer:
1 Attachment(s)
Here you are sir.
Greetings LWhitson2,
OK, this one is going to be a bit weird to fix. So the problem is that the latest 2.3.x repository has been prepared to bridge into the 2.4 release, which is essentially what would have been 2.3.2 in the previous numbering. The result: CGAL, Scotch and some other libraries were updated in the "OpenFOAM-2.3.x/etc/config/*" files, as well as in the ThirdParty-2.3.x folder. The situation you're in is that the "OpenFOAM-2.3.x" repository was recently configured into using CGAL 4.6, but the script "makeCGAL" in "ThirdParty-2.3.x" is still hard-coded to use 4.3. This makes the "Allwmake" script in "ThirdParty-2.3.x" to go look if CGAL 4.6 is installed and since it can't find it, it calls "makeCGAL", which in turn will build CGAL 4.3. So, how to fix this? It depends on what you prefer to do:
Bruno |
I've reported the issues with the versions here: http://www.openfoam.org/mantisbt/view.php?id=1705 - Henry has asked for feedback on who agrees with reverting the versions for CGAL, Open-MPI and Scotch on OpenFOAM 2.3.x.
As for the repositories:
