September 24, 2015, 09:38 |
openFoam for windows 15.06 error
Karlis
Rep Power: 11 |
Hi all, I have (successfully) installed openFoam for windows and started to work on a tutorial case presented here:
http://the-foam-house5.webnode.es/products-/ I have discovered that my terminal is giving me an error every time I am trying to run any openFoam executables. Here is the error: /opt/OpenFOAM/OpenFOAM-2.3.x/platforms/cygwin64mingw-w64DPOpt/bin/blockMesh.exe: error while loading shared libraries: ?: cannot open shared object file: No such file or directory Is there anything I can do? I run windows 7. Thanks! |
September 27, 2015, 17:02 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I believe there is a thread on this topic: http://www.cfd-online.com/Forums/ope...pport-com.html - I haven't confirmed if the answer to your question is available there.
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
