Minimize OF disk requirements
Like Tree3Likes
  • 3 Post By wyldckat
Old   October 2, 2015, 07:57
Default Minimize OF disk requirements
Ruggiero Guida
Rojj is on a distinguished road
Hi, I have built OF from source on an amazon EC2 instance. Because space is quite precious I wonder what are the files that I need to keep in order to have a functioning installation.
I have followed the standard instructions to build from source so my installation tree looks like this (from ~):
OpenFOAM/
├── OpenFOAM-2.4.0
│** ├── Allwmake
│** ├── applications
│** ├── bin
│** ├── COPYING
│** ├── doc
│** ├── etc
│** ├── platforms
│** ├── README.html
│** ├── README.org
│** ├── src
│** ├── tutorials
│** └── wmake
├── ThirdParty-2.4.0
│** ├── Allclean
│** ├── Allwmake
│** ├── AllwmakeLibccmio
│** ├── build
│** ├── CGAL-4.6
│** ├── cmake-2.8.12.1
│** ├── etc
│** ├── makeCGAL
│** ├── makeCmake
│** ├── makeGcc
│** ├── makeLLVM
│** ├── makeParaView
│** ├── makeParaView4
│** ├── makeQt
│** ├── openmpi-1.8.5
│** ├── ParaView-4.1.0
│** ├── platforms
│** ├── README.html
│** ├── README.org
│** └── scotch_6.0.3
└── ubuntu-2.4.0
├── platforms
├── run
└── swak4Foam
My guess is that ThirdParty-2.4.0 can be deleted and so all the docs and tutorials. But can I get rid of all the sources?
The idea is to create an image that is used only for the calculation and uses the minimum amount of space.
Thanks
Rojj is offline   Reply With Quote
Old   October 2, 2015, 14:55
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
If space is so small that the installation itself is problematic, you're going to run into serious problems trying to store any sizable CFD solution data set.
kmooney is offline   Reply With Quote
Old   October 3, 2015, 12:06
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Quick answer: If you no longer need to build anything at all from source code, then you only need 5 folders:
  • OpenFOAM-*
    • bin
    • etc
    • platforms
  • ThirdParty-*
    • platforms
  • username-*
    • platforms
cutter, Rojj and macelee like this.
Last edited by wyldckat; October 3, 2015 at 12:07. Reason: revised the folders you need
Old   October 5, 2015, 19:21
Ruggiero Guida
Thanks Bruno. That's what I needed.
@kmooney
I will keep that in mind. At the moment my files are not very big as I am in development. Practically I run the case, sample a few points, download the results and delete the case.
Thread Tools
Trackbacks are On
actuator disk Atit CFX 9 July 26, 2016 09:39
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 8 July 3, 2014 10:54
vof rotating disk 2d bene FLUENT 1 October 24, 2010 13:18
vof sliding disk help please bene FLUENT 0 October 22, 2010 04:10
Actuator Disk Model sujialin CFX 0 April 18, 2010 16:29
