[OpenFOAM.org] Installation problem 2.4.0 on Centos 6.6 |
#1 | ||
Luke Skywalker
Rep Power: 8 ![]() |
I followed the instructions for OF 2.4.0 on Centos 6.6 on this wiki:
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL but at the end when I run the Quote:
http://www.pi.ingv.it/make.log.gz |
Retired Super Moderator
Bruno Santos
Rep Power: 122 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: Something went wrong with the build of the custom GCC 4.8.4, because the first error message you are getting is related to using an outdated GCC:
primitives/triad/triad.C:36: error: expected initializer before '<' token primitives/triad/triad.C:39: error: expected initializer before '<' token Code:
which gcc which g++ export |
Luke Skywalker
below can you see the output:
[prova@hpc-sm OpenFOAM-2.4.0]$ which gcc /usr/bin/gcc [prova@hpc-sm OpenFOAM-2.4.0]$ which g++ /usr/bin/g++ [prova@hpc-sm OpenFOAM-2.4.0]$ export declare -x ANT_HOME="/opt/rocks" declare -x BOOST_ARCH_PATH="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/boost_1_54_0" declare -x CGAL_ARCH_PATH="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/CGAL-4.6" declare -x CMAKE_HOME="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/cmake-2.8.12.1" declare -x CVS_RSH="ssh" declare -x DISPLAY=":0.0" declare -x FOAM_APP="/home/prova/OpenFOAM/OpenFOAM-2.4.0/applications" declare -x FOAM_APPBIN="/home/prova/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc48DPOpt/bin" declare -x FOAM_ETC="/home/prova/OpenFOAM/OpenFOAM-2.4.0/etc" declare -x FOAM_EXT_LIBBIN="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48DPOpt/lib" declare -x FOAM_INST_DIR="/home/prova/OpenFOAM" declare -x FOAM_JOB_DIR="/home/prova/OpenFOAM/jobControl" declare -x FOAM_LIBBIN="/home/prova/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc48DPOpt/lib" declare -x FOAM_MPI="openmpi-system" declare -x FOAM_RUN="/home/prova/OpenFOAM/prova-2.4.0/run" declare -x FOAM_SETTINGS="WM_NCOMPPROCS=46 foamCompiler=system WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI" declare -x FOAM_SIGFPE="" declare -x FOAM_SITE_APPBIN="/home/prova/OpenFOAM/site/2.4.0/platforms/linux64Gcc48DPOpt/bin" declare -x FOAM_SITE_LIBBIN="/home/prova/OpenFOAM/site/2.4.0/platforms/linux64Gcc48DPOpt/lib" declare -x FOAM_SOLVERS="/home/prova/OpenFOAM/OpenFOAM-2.4.0/applications/solvers" declare -x FOAM_SRC="/home/prova/OpenFOAM/OpenFOAM-2.4.0/src" declare -x FOAM_TUTORIALS="/home/prova/OpenFOAM/OpenFOAM-2.4.0/tutorials" declare -x FOAM_USER_APPBIN="/home/prova/OpenFOAM/prova-2.4.0/platforms/linux64Gcc48DPOpt/bin" declare -x FOAM_USER_LIBBIN="/home/prova/OpenFOAM/prova-2.4.0/platforms/linux64Gcc48DPOpt/lib" declare -x FOAM_UTILITIES="/home/prova/OpenFOAM/OpenFOAM-2.4.0/applications/utilities" declare -x G_BROKEN_FILENAMES="1" declare -x HISTCONTROL="ignoredups" declare -x HISTSIZE="1000" declare -x HOME="/home/prova" declare -x HOSTNAME="hpc-sm.pi.ingv.it" declare -x JAVA_HOME="/usr/java/latest" declare -x LANG="en_US.iso885915" declare -x LD_LIBRARY_PATH="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/boost_1_54_0/lib:/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/CGAL-4.6/lib:/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/gperftools-svn/lib:/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/ParaView-4.1.0/lib/paraview-4.1:/home/prova/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc48DPOpt/lib/openmpi-system:/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48DPOpt/lib/openmpi-system:/usr/lib64/openmpi/lib:/home/prova/OpenFOAM/prova-2.4.0/platforms/linux64Gcc48DPOpt/lib:/home/prova/OpenFOAM/site/2.4.0/platforms/linux64Gcc48DPOpt/lib:/home/prova/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc48DPOpt/lib:/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48DPOpt/lib:/home/prova/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc48DPOpt/lib/dummy:/opt/openmpi/lib:/opt/python/lib" declare -x LESSOPEN="||/usr/bin/lesspipe.sh %s" declare -x LOADEDMODULES="rocks-openmpi:openmpi-x86_64" declare -x LOGNAME="prova" declare -x LS_COLORS="rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.tbz=01;31:*.tbz2=01;31:*.bz=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:" declare -x MAIL="/var/spool/mail/prova" declare -x MANPATH="/usr/share/man/openmpi-x86_64:/opt/torque/man:" declare -x MAVEN_HOME="/opt/maven" declare -x MODULEPATH="/usr/share/Modules/modulefiles:/etc/modulefiles" declare -x MODULESHOME="/usr/share/Modules" declare -x MPIHOME="/opt/openmpi" declare -x MPI_ARCH_PATH="/usr/lib64/openmpi" declare -x MPI_BIN="/usr/lib64/openmpi/bin" declare -x MPI_BUFFER_SIZE="20000000" declare -x MPI_COMPILER="openmpi-x86_64" declare -x MPI_FORTRAN_MOD_DIR="/usr/lib64/gfortran/modules/openmpi-x86_64" declare -x MPI_INCLUDE="/usr/include/openmpi-x86_64" declare -x MPI_LIB="/usr/lib64/openmpi/lib" declare -x MPI_MAN="/usr/share/man/openmpi-x86_64" declare -x MPI_PYTHON_SITEARCH="/usr/lib64/python2.6/site-packages/openmpi" declare -x MPI_SUFFIX="_openmpi" declare -x MPI_SYSCONFIG="/etc/openmpi-x86_64" declare -x OLDPWD="/home/prova/OpenFOAM/ThirdParty-2.4.0" declare -x OMPI_MCA_btl="self,sm,tcp" declare -x PATH="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/gperftools-svn/bin:/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/ParaView-4.1.0/bin:/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/cmake-2.8.12.1/bin:/home/prova/OpenFOAM/prova-2.4.0/platforms/linux64Gcc48DPOpt/bin:/home/prova/OpenFOAM/site/2.4.0/platforms/linux64Gcc48DPOpt/bin:/home/prova/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc48DPOpt/bin:/home/prova/OpenFOAM/OpenFOAM-2.4.0/bin:/home/prova/OpenFOAM/OpenFOAM-2.4.0/wmake:/usr/lib64/openmpi/bin:/opt/openmpi/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/ganglia/bin:/opt/ganglia/sbin:/usr/java/latest/bin:/opt/maven/bin:/opt/maui/bin:/opt/torque/bin:/opt/torque/sbin:/opt/pdsh/bin:/opt/rocks/bin:/opt/rocks/sbin:/home/prova/bin" declare -x PDSHROOT="/opt/pdsh" declare -x PV_PLUGIN_PATH="/home/prova/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc48DPOpt/lib/paraview-4.1" declare -x PWD="/home/prova/OpenFOAM/OpenFOAM-2.4.0" declare -x PYTHONPATH="/usr/lib64/python2.6/site-packages/openmpi" declare -x ParaView_DIR="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/ParaView-4.1.0" declare -x ParaView_INCLUDE_DIR="/home/prova/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc48/ParaView-4.1.0/include/paraview-4.1" declare -x ParaView_MAJOR="4.1" declare -x ParaView_VERSION="4.1.0" declare -x QTDIR="/usr/lib64/qt-3.3" declare -x QTINC="/usr/lib64/qt-3.3/include" declare -x QTLIB="/usr/lib64/qt-3.3/lib" declare -x ROCKSROOT="/opt/rocks/share/devel" declare -x ROCKS_ROOT="/opt/rocks" declare -x ROLLSROOT="/opt/rocks/share/devel/src/roll" declare -x SHELL="/bin/bash" declare -x SHLVL="1" declare -x SSH_ASKPASS="/usr/libexec/openssh/gnome-ssh-askpass" declare -x TERM="xterm" declare -x USER="prova" declare -x WM_ARCH="linux64" declare -x WM_ARCH_OPTION="64" declare -x WM_CC="gcc" declare -x WM_CFLAGS="-m64 -fPIC" declare -x WM_COMPILER="Gcc48" declare -x WM_COMPILER_LIB_ARCH="64" declare -x WM_COMPILE_OPTION="Opt" declare -x WM_CXX="g++" declare -x WM_CXXFLAGS="-m64 -fPIC" declare -x WM_DIR="/home/prova/OpenFOAM/OpenFOAM-2.4.0/wmake" declare -x WM_LDFLAGS="-m64" declare -x WM_LINK_LANGUAGE="c++" declare -x WM_MPLIB="SYSTEMOPENMPI" declare -x WM_NCOMPPROCS="46" declare -x WM_OPTIONS="linux64Gcc48DPOpt" declare -x WM_OSTYPE="POSIX" declare -x WM_PRECISION_OPTION="DP" declare -x WM_PROJECT="OpenFOAM" declare -x WM_PROJECT_DIR="/home/prova/OpenFOAM/OpenFOAM-2.4.0" declare -x WM_PROJECT_INST_DIR="/home/prova/OpenFOAM" declare -x WM_PROJECT_USER_DIR="/home/prova/OpenFOAM/prova-2.4.0" declare -x WM_PROJECT_VERSION="2.4.0" declare -x WM_THIRD_PARTY_DIR="/home/prova/OpenFOAM/ThirdParty-2.4.0" declare -x _LMFILES_="/usr/share/Modules/modulefiles/rocks-openmpi:/etc/modulefiles/openmpi-x86_64" Last edited by wyldckat; November 10, 2015 at 16:31. Reason: Changed [QUOTE][/QUOTE] to [CODE][/CODE] |
Bruno Santos
Quick answer: Well, this line explains the problem:
FOAM_SETTINGS="WM_NCOMPPROCS=46 foamCompiler=system WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI" The instructions on the wiki, step #7, specifically state the option that should be used is "foamCompiler=ThirdParty". In addition, using "WM_NCOMPPROCS=46" is a bit much... I advise you to use 8 or 16... more than that could result in some weird situations... |
Luke Skywalker
you are right! It was outdated GCC problem. I updated the gcc system in my centos 6.6 with
devtools-1.1 to 4.7 GCC version and Allwmake is terminated with no errors |
#6 | |
Luke Skywalker
I tried to use "foamCompiler=ThirdParty" but I received this warning:
Thanks for your help! |
If you would like to use ThirdParty compiler, you have to compile it first (i.e. download sources for gcc, gmp, mpc, mpfr and use makeGcc script). If you are using Gcc 4.7 from devtoolset, it would be much easier to follow "Source Pack Installation" at http://openfoam.org/archive/2.4.0/download/source.php (leave foamCompiler=system). Though since atrpms repository vanished, you have to skip CGAL and QT parts from there (either build them yourself or use paraview & boost RPM packages, drop CGAL-dependent parts). |
#8 | |
Bruno Santos
Greetings to all!
To add to Alexey's answer, if the initially mentioned wiki page is followed properly: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.6 - at the end of step #7, the following is written about this error message: Quote:
Best regards, Bruno |
#9 |
Luke Skywalker
I recompiled with foamCompiler=ThirdParty and, after warning, I continued to follow the instructions and everything worked perfectly!
Display Modes | |
[OpenFOAM.com] Installation Problem | Manyway | OpenFOAM Installation | 2 | July 8, 2016 14:47 |
installation Problem - Linux distribution (Not a meshing problem) | v_herw | Pointwise & Gridgen | 2 | June 20, 2016 15:47 |
[swak4Foam] swak4foam 0.3.2 installation problem on Ubuntu 15.04 with OpenFOAM 2.4.0 | ptsxx | OpenFOAM Community Contributions | 1 | January 10, 2016 18:48 |
Installation problem - calling blockMesh - libblockMesh.so | aylalisa | OpenFOAM Installation | 5 | November 28, 2012 10:55 |
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 | Wley | OpenFOAM Installation | 2 | September 28, 2012 07:06 |
