[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview
Old   January 23, 2016, 07:12
Question Openfoam for windows 16.02 [CFD support] -problem with paraview
ditmeyer is on a distinguished road
hi all,
I have a problem with the new version of openfoam for windows (version 16.02) released by CFD support.
The problem occurs when I try to launch paraview with the command "paraview" or with the "paraFoam" command an error occurs :
 "ERROR: In C:\msys\1.0\opt\ParaView-v5.0.0-RC1-source\ParaViewCore\ClientServerCore\Rendering\vtkPVSynchronizedRenderWindows.cxx, line 408 vtkPVSynchronizedRenderWindows (0x8b36760): Invalid process type. Segmentation fault
this is the error in paraview:
I tried to find something on internet but it didn't find anything. I also tried to install again paraview but the problem stays. I never had this problem with the last version of Openfoam windows by CFD support (version 15.06).
The installation went well, except with parallel MPI, that already was installed in my computer (maybe the problem is here, but I don't think so).
I'm using windows 10, 64 bits.
Does someone have had the same problem when installing this new version ?
Thank you in advance for your help
ditmeyer is offline   Reply With Quote
Old   January 28, 2016, 22:53
Default paraFoam problem
Lionel Pullum
Lonelp is on a distinguished road
I have exactly the same problem with Win 64 bit machine.
Anybody have a solution?
Lonelp is offline   Reply With Quote
Old   March 11, 2017, 14:08
Default Same Problem
maulik kotecha
MK007 is on a distinguished road
I installed openFOAM first time today. I was trying my first sample example and this problem occurred.
MK007 is offline   Reply With Quote
Old   May 15, 2017, 12:04
Default Launching ParaView from Cygwin
Jakub Benda
jacop is on a distinguished road
It seems that this happens only when launching ParaView from the Cygwin command shell (using the command paraview or paraFoam). In my case the problem was caused by too long PATH variable in Cygwin.
Try to modify the last line of the file /opt/OpenFOAM/OpenFOAM-3.0.x/bin/paraview to contain
PATH="" $path/paraview "$@"
instead of the original
exec $path/paraview "$@"
This worked for me.
jacop is offline   Reply With Quote
cfdsupport, openfoam, parafoam, paraview
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
Updated native OpenFOAM reader for ParaView 5.3 opencfd OpenFOAM Announcements from ESI-OpenCFD 4 July 13, 2017 10:14
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 ad2eb OpenFOAM Installation 12 May 28, 2017 14:30
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 06:39
OpenFOAM141 FoamX and paraView problem on cluster server seigi OpenFOAM Installation 1 January 28, 2008 15:44
