OpenFoam installation on CentOS 7 32 bits
I'm new user of OpenFoam... i have looked for installation instructions of OF on CentOS 7 32 bits and did not found ... Only for 64 bits does exist , there is no suppport for 32 bits !. any help will be appreciated. By the way.. which version of OF is recommanded ?, the lastest ? Thanks |
Quick questions:
Thank you for the quick reply,
Anyway, in my case i will install CentOS 6.x ... however to reply to your questions: . CentOS 7 i386 (32 bits) was released last December . http://mirror.centos.org/altarch/7/isos/i386/ |
Greetings donminoti,
Many thanks for the feedback and thank you for choosing to use CentOS 6 i386 instead of 7. I say this because CentOS 7 i386 is part of the AltArch special interest groups and these special versions currently don't have repositories on the EPEL section at the Fedora project :( This means that I would have had to write dedicated instructions for CentOS 7 i386 and that it would have to rely on either not relying on Qt-Webkit while building ParaView, or it would require building Qt from source code. This to say that this isn't very hard, since on my end I would essentially copy-paste-adapt instructions from other versions I've already written for, but the downside is that it would take me between 3 to 6 hours to have the chapter written and fully tested :( I would be able to do other stuff during the compilation phases, but the computer would be mostly busy with it and limiting what I could do in the meantime. Best regards, Bruno |
