root in openfoam docker
I pulled the openfoam docker, which is built on centos which i'm not familiar with (I am an ubuntu user) . 'sudo' isn't recognized nor are my usual texteditors (nano, emacs) , nor can i install with yum without being root....so unless someone has some way out I guess I will just install on the metal and skip the docker which otherwise seems like a nice idea.
It seems that you can access to root with the same password as the root acount in your local linux system.
It worked for me. Regards Robert |
start your system in virtual box.run "passwd".It will require a new password, set one.Start your Docker and openfoam.Type su and input the password you set. |
I tried OpenFOAM v1706 on Ubuntu 16.04, using the Docker-installation method, which is based on the installOpenFOAM and a startOpenFOAM scripts.
A workaround I found to login as root inside was to edit the startOpenFOAM script and modify: Code:
docker exec -it of_v1706 /bin/bash -rcfile /opt/OpenFOAM/setImage_v1706.sh Code:
docker exec -u 0 -it of_v1706 /bin/bash -rcfile /opt/OpenFOAM/setImage_v1706.sh |
