anonymous
Rep Power: 8 ![]() |
Hi All,
I recently installed ubuntu 15.10 and OpenFOAM+ following the directions given on the OPenFOAM (Binary Installation) web page. Everything worked out until I reached at the following instructions: ************************************************** mkdir -p $FOAM_RUN run cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity . cd cavity blockMesh icoFoam paraFoam ************************************************** I was able to run all above commands except paraFoam. This command brings the paraView graphical screen but does not show any result or geometry. When I checked on terminal I am receiving error message as: libGL error: failed to open drm device: NO such file or directory libGL error: failed to load driver: i915 I need help to resolve this error. I am window user and does not have expertise in using Linux/Unix type environment. Thanks in advance |
Pawan Ghildiyal
hi Are you able to resolve the issue ?
anonymous
I did nothing, but when I turned on machine next day it worked out. Try to reboot machine, it might work.
driver-load-error |
Display Modes | |
[OpenFOAM] Unable to launch parafoam & | boonhow | ParaView | 5 | March 23, 2022 08:09 |
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] | u2berggeist | OpenFOAM Installation | 2 | July 2, 2018 17:03 |
[OpenFOAM] How to use paraFoam on a cluster | andreas | ParaView | 1 | March 6, 2013 17:11 |
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY | raketenmaid | ParaView | 4 | February 5, 2013 05:20 |
[OpenFOAM] Parafoam basic questions | qtian | ParaView | 0 | July 20, 2007 11:52 |
