[OpenFOAM.com] Error: Windows Installation
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 4, 2016, 14:00
Default Error: Windows Installation
anonymous
cute is on a distinguished road
Hi All,
I am trying to install openfoam on Win 7 using the installer provided. I followed all instructions but I am getting some error messages. A screen shot is attached. Please help me installing this software.
Note: I manually started boot2Docker.
Thanks.
cute is offline   Reply With Quote
Old   April 4, 2016, 14:15
pgh
Pawan Ghildiyal
pgh is on a distinguished road
There is issue with installation .. Any reason why it is being run as administrator. i.e your snapshot show it is being run as administrator.
Also i assume virtualization is enable in your system , if not please enable it and then reboot system twice and reinstall everything after un-installing all component plus other instruction as given in readme file
pgh is offline   Reply With Quote
Old   April 4, 2016, 15:33
anonymous
I used havdetectiontool, does it enable hardware visualization? If not, how can I do this?
Don't worry, I checked that hardware visualization is enabled. I will reinstall tomorrow and post the result.
Old   April 5, 2016, 04:48
pgh
Pawan Ghildiyal
From http://openfoam.com/download/txt/ope...adme_v3.0+.txt
First check whether it is enable or not
1) Hardware assisted virtualization should be enabled. If not already done, please enable it from the BIOS mode(see below), then reboot your system twice before proceeding with this Installation. In Windows7, check if hardware-assisted Virtualization is switched on by running the Windows utility https://www.microsoft.com/en-us/down...d=592#filelist
2. Search internet how to enable hardware virtualization in windows 7. Ideally, you need to go to go BIOS settings and enable virtualization .
https://access.redhat.com/documentat...s_in_BIOS.html
Old   April 22, 2016, 15:44
David
RichlandDavid is on a distinguished road
Originally Posted by guest1044 View Post
has anybody already tried (and succeeded) to install OpenFOAM-3.0.x on Windows with mingw or anyhow else? Any hint in that direction would be helpful!
Best regards,
Alice
Hi Alice. I'm trying as well, on a Sony Vario Windows 8.1 64 bit machine. Installation went well but I cannot get the program to run. Am trying to figure it out. I enabled virtualization. And have restarted many times.
Last edited by wyldckat; May 1, 2016 at 17:35. Reason: added quote, after moving this and the post below from the other thread
RichlandDavid is offline   Reply With Quote
Old   April 28, 2016, 10:46
Default Problem in running OpenFoam
Danielle Matsumoto
dani_BR is on a distinguished road
I installed too, but I couldnīt run it.
Te attached error appeared when I openned the program.
dani_BR is offline   Reply With Quote
Old   May 1, 2016, 18:54
Retired Super Moderator
Bruno Santos
Please provide more details, so that we can help you.
An FAQ section was added recently to the download page for the OpenFOAM+ 3.0+ installer for Windows: http://www.openfoam.com/download/install-windows.php
pgh likes this.
Old   May 5, 2016, 04:53
mqsim is on a distinguished road
I would suggest to use the following link to install OpenFoam under windows:
http://www.cfdsupport.com/download-o...r-windows.html
Best regards,
mqsim
mqsim is offline   Reply With Quote
how do i fix installation error of ansys 19.0 on ubuntu 18.04 rid_taki ANSYS 15 June 7, 2021 06:32
[foam-extend.org] A smooth installation of foam-3.0-extend on OpenSUSE 13.1 64-bits cookcaptain OpenFOAM Installation 7 May 26, 2015 11:22
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
