[OpenFOAM.org] Arch Linux unofficial repository for OpenFOAM |
April 23, 2016, 11:23 |
Linya Wu
I have just set up a repository for OpenFOAM for Arch linux. Please add the following into /etc/pacman.conf [home_Minerva_W_Science_Arch_Extra] SigLevel = Never Server = http://download.opensuse.org/repositories/home:/Minerva_W:/Science/Arch_Extra/$arch for installing pacman -S openfoam3.0.1 Note: Still has a little problem with foamyQuadMesh and foamyHexMesh as libboost_thread.so is not linked. I am now patching the option file and recompiling locally to see if the problem still exists, after that I will upload the new build file. As the OpenSUSE build system is slow, the recompile will take about one day. Other functions seems OK in the package so far. Update 4/24 openfoam foamyQuadMesh and foamyHexMesh repaired. As I am using system paraview for the build (5.0.1), PV4Reader plugin is excluded (and seems unnecessary...), but I will give it a try. Update PV4Reader plugin is compiled, and the two plugin files loads without problem into paraview. but I don't know whether it works properly. Update 5/2 Added openfoam 3.0.x git version. It seems that there is no need to compile PV4Reader plugin as ParaView for Archlinux can work properly with paraFoam without the plugin loaded. However, if I want to compile the reader plugin I will have to install the development file of paraview in CMake, which results in a conflict with vtk package of Arch Linux. So I took out the plugin in the most recent build. Plz reply if there are any difference with and without the plugin loaded (which I didn't notify when running test case). I will move the ParaView to /opt. Last edited by Miss_Mini; May 2, 2016 at 10:37. |
May 1, 2016, 18:11 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Linya Wu,
Many thanks for doing and sharing this effort! I've kicked off a wiki page for this here: http://openfoamwiki.net/index.php/In...0.1/Arch_Linux - please do feel free to edit the wiki page to add your instructions and also feel free to add pages for other OpenFOAM versions if you wish to! The central point with informations on how to add these wiki pages is here: http://openfoamwiki.net/index.php/Installation/Linux Best regards, Bruno
May 22, 2016, 11:35 |
Rep Power: 9 |
after installing the package with pacman i do not seem to be able to run openfoam. I run Code:
source /etc/openfoam-3.0.1.sh Could you help me? Thanks a lot Last edited by mgab; May 22, 2016 at 15:36. |
July 10, 2016, 12:51 |
Ed
Rep Power: 10 |
Hi Mgab
OpenFOAM is not a single executable. It is a collection of executables which do different things (e.g. executables for meshing, incompressible flow, multiphase flow, scalar transport etc). If you follow the end of the installation guide, it will show you how to run a tutorial. If the tutorials work well, it means your installation was good. Look at the tutorials to see how they use the different executables. This is one big advantage of OF over Fluent for example. You only need to run the programs you need, and not one big dirty clunky monolithic executable. |
Fluent 19.2 Instalation on linux | backuproot | FLUENT | 0 | October 12, 2018 10:20 |
[OpenFOAM.org] Installing OpenFOAM 3.0.1 from Arch unofficial repository | mgab | OpenFOAM Installation | 0 | May 26, 2016 08:55 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 11:51 |
libOSSpecific.o does not compile on Arch Linux | AlmostSurelyRob | OpenFOAM Installation | 1 | April 17, 2012 05:07 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
