Problem with GLIBCXX when installing OpenFOAM using ICC compiler
2 Attachment(s)
Dear Foamers,
I am trying to install OpenFOAM in the cluster with following specs: Code:
[nnvan@aadl FL35_14]$ uname -a HTML Code:
https://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-2.2.2/CentOS_SL_RHEL Code:
module load mpi/openmpi-1.8.4-intel2015; source $HOME/OpenFOAM/OpenFOAM-2.2.2/etc/bashrc WM_NCOMPPROCS=4 WM_COMPILER=Icc WM_MPLIB=SYSTEMOPENMPI Code:
[nnvan@aadl FL35_14]$ blockMesh Best regards, Loc |
Hi Loc,
Sorry for the late reply, but only now did I manage to take a quick look into this... and I was hoping for anyone else to help you sooner, but that didn't happen :( Something is wrong or missing in the machine you're using. Because this message is consistently showing up in both log files: Code:
/appl/compiler/gcc-5.2/libexec/gcc/x86_64-unknown-linux-gnu/5.2.0/cc1: error while loading shared libraries: libmpc.so.2: cannot open shared object file: No such file or directory Please check with the cluster administrators on how to fix this issue, given that GCC 5.2 is being used, but bits and pieces are still missing, namely the MPC library. This should also be related to the problem with GLIBCXX, given that even though ICC was used with success, it apparently refers to the same libraries that GCC 5.2 is using, but which are missing. Best regards, Bruno |
Dear Mr. Bruno,
Thank you very much for the reply, I've been really worried that there are no solution for this problem. It is a very useful information, again, thank you a lot! I will revert to you again when the problem is fixed. Best regards, Loc |
