[OpenFOAM.com] wmake error: file 'Make/linux64Gcc44DPOpt/objectFiles' could not be created
Like Tree26Likes
  • 1 Post By l_r_mcglashan
  • 1 Post By auvinen
  • 8 Post By l_r_mcglashan
  • 1 Post By auvinen
  • 1 Post By kokkonee
  • 1 Post By auvinen
  • 1 Post By auvinen
  • 1 Post By mihir1310
  • 1 Post By lakeat
  • 2 Post By elham usefi
Old   November 20, 2009, 07:02
Default wmake error: file 'Make/linux64Gcc44DPOpt/objectFiles' could not be created
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Hello everyone,
I cloned the OF-1.6 Git repository and downloaded the Third Party stuff. When I run Allwmake (using gcc-4.4.2 on 64bit Fedora 12) on the 1.6.x directory I get the following errors to do with wmake:
Note: ignore spurious warnings about missing mpicxx.h headers
+ WM_OPTIONS=linux64Gcc44DPOptOPENMPI
+ wmake libso mpi
'/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/lib/linux64Gcc44DPOpt/openmpi-1.3.3/libPstream.so' is up to date.
+ wmake libo OSspecific/POSIX
'/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/lib/linux64Gcc44DPOpt/libOSspecific.o' is up to date.
+ wmake libso OpenFOAM
linux64Gcc44DPOpt/options:6: *** missing separator.  Stop.
+ wmake libso lagrangian/basic
SOURCE=indexedParticle/indexedParticleCloud.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40  -IlnInclude -I. -I/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc44DPOpt/indexedParticleCloud.o
'/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/lib/linux64Gcc44DPOpt/liblagrangian.so' is up to date.
+ wmake libso triSurface
The OpenFOAM Make/options looks like:
EXE_INC = \
    -I$(WM_THIRD_PARTY_DIR)/zlib-1.2.3
LIB_LIBS = \
    $(FOAM_LIBBIN)/libOSspecific.o \
    -L$(FOAM_LIBBIN)/dummy -lPstream \
    -lz
The OpenFOAM linux64GccDPOpt/options file looks like:
# 1 "options"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "options"
EXE_INC =
LIB_LIBS =
    -lz
Does anyone have an idea what this missing separator error with wmake means?
Thanks.
Lehaibmo likes this.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   November 23, 2009, 05:22
Update: There is something weird going on with the separators (you might say 'duh', looking at the error messages) that wmake generates in the options file. If I manually correct the options file created in Make/linux64GccDPOpt/, and then run wmake, it compiles fine.
Old   November 27, 2009, 09:58
SOLVED
It was something to do with 'cpp'. The system 'cpp' with GCC 4.4.2 on Fedora 12 screws up the separators.
Fix:
Edit wmake/rules/linux64Gcc/general so that CPP = ThirdParty-1.6/gcc-4.3.3/platforms/bin/cpp instead of /lib/cpp.
Old   January 5, 2010, 11:34
Default Odd problem
Mikko Auvinen
auvinen is on a distinguished road
Originally Posted by l_r_mcglashan View Post
SOLVED
Fix:
Hi Laurence,
I'm facing exactly the same problem on my Fedora 12: make complains about missing separators with every single linux64GccDPOpt/options file. It seems as if the files have been corrupted in some way -- the TAB characters have gone missing or something. The only way I can make things work is by manipulating the files by hand. I tried your Fix, but I cannot get things to work. Could you please elaborate a little on what you did after you edited the rules file in wmake?
I'm trying to compile 1.6 and 1.5-dev on my new machine and I have the same problem with both.
Gratefully,
- mikko
auvinen is offline   Reply With Quote
Old   January 5, 2010, 12:12
Have you done 'wclean' before redoing wmake? wmake searches for the folder Make/linuxGccblahblah and the files in it before executing.
Old   January 7, 2010, 04:53
Default Solved indeed
Mikko Auvinen
That's the ticket! Apparently I had not done 'wclean' before running wmake again. Everything works fine now. Thank you very much.
Just to clarify the issue for potential readers, this problem arose with me irrespective of the compiler choice (compilerInstall=System/OpenFOAM) in settings.sh; wmake tries to utilize the system cpp by default.
Good work Laurence!
Old   January 7, 2010, 08:49
Glad it was of use to you! Problems like this are why Fedora is so much fun. . It's a poor workaround really, at least it gets the job done.
Old   January 13, 2010, 17:18
Default OpenFOAM-1.5-dev: Make/linux64GccDPOpt/objectFiles' could not be created
Eero Kokkonen
kokkonee is on a distinguished road
Hello!
I am getting the same error with OpenFOAM-1.5-dev (I need the GGI) on Fedora 12 (64-bit) and Ubuntu 9.10 (32-bit) as mentioned here.
This is the basic form that I have tried:
First got these:
flex
binutils
binutils-dev
cmake
gcc-c++
qt4
1)
Get the OpenFOAM-1.5-dev and Thirdparty files for 1.5-version:
svn co https://openfoam-extend.svn.sourcefo...enFOAM-1.5-dev OpenFOAM-1.5-dev
http://sourceforge.net/projects/foam....gtgz/download
tar xzf ThirdParty.General.gtgz
tar xzf ThirdParty.linuxGcc.gtgz
2)
changed:
OpenFOAM-1.5-dev/etc/settings.sh
#compilerInstall=OpenFOAM
to:
#compilerInstall=System
3)
Added $HOME/.bashrc the following line:
source $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc
and sourced (or opened new terminal)
4) Have done
./Allwmake >& log_Allwmake
The log can be found here:
http://www.students.tut.fi/~kokkonee/OpenFOAM/log_Allwmake
In addition I have tried
i) FIX up for Ubuntu 9.10
cd ~/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/lib
mv libstdc++.so.6 libstdc++.so.6.orig
ln -s /usr/lib/libstdc++.so.6.0.13 libstdc++.so.6
mv libgcc_s.so.1 libgcc_s.so.1.orig
ln -s /lib/libgcc_s.so.1
ii) and with Fedora 12
http://www.cfd-online.com/Forums/ope...uccessful.html
If someone could please help me with this, I am clearly missing something and I and confused from all the things I have read and tried...
BR.
Eero Kokkonen
eero.kokkonen(at)tut.fi
kokkonee is offline   Reply With Quote
Old   January 14, 2010, 04:12
Mikko Auvinen
Eero,
Referring to the Fedora 12 problem, you're looking at a fix to the "missing separator" issue on this thread. I was able compile both 1.5-dev and 1.6 on F12 after I followed Laurence's recipe on changing the cpp used by wmake. ... Just remember to run wclean after you make the change.
- mikko
Old   January 14, 2010, 04:22
Although I would now use the fix of adding the 'P' option to the cpp command discussed in the following thread:
http://www.cfd-online.com/Forums/ope...dora-12-a.html
Old   January 14, 2010, 04:50
Mikko Auvinen
Yes, that's a much nicer fix.Thanks again.
- mikko
Old   January 17, 2010, 07:28
Default still problems...
  #12
Eero Kokkonen
Hi!
I have tried the -P option suggested in this thread, but it is not working for me (fedora 12, 64-bit).
I started from the beginning (deleted all files) and did the following:
1)
2)
changed:
to:
3)
4)
Compiled the Qt-4.3.5 version
and added the following lines to the ~/OpenFOAM/OpenFOAM-1.5/etc/bashrc at the very end
# set QT related variables
QT=~/OpenFOAM/ThirdParty/Qt-4.3.5
export PATH=$QT/bin:$PATH
export LD_LIBRARY_PATH=$QT/lib:$LD_LIBRARY_PATH
Have you guys done this with your Fedora distributions? I read that people have got everything working with this (http://www.cfd-online.com/Forums/ope...am-ubuntu.html). I also tried without this, not working...
5)
I modified the file: OpenFOAM-1.5-dev/wmake/rules/linux64Gcc/general
CPP = /lib/cpp $(GFLAGS) -P
LD = ld -A64
PROJECT_LIBS = -l$(WM_PROJECT) -liberty -ldl
include $(GENERAL_RULES)/standard
include $(RULES)/X
include $(RULES)/c
include $(RULES)/c++
include $(GENERAL_RULES)/cint
Isn't this the correct file in my case (though I also tried the OpenFOAM-1.5-dev/wmake/rules/linuxGcc/general -file)?
6) Did
Still got these wmake errors:
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
make[1]: *** [setFields] Error 1
linux64GccDPOpt/options:6: *** missing separator. Stop.
make[1]: *** [mapFields] Error 1
make[1]: Target `application' not remade because of errors.
make: *** [preProcessing] Error 2
make: Target `application' not remade because of errors.
+ '[' '' = doc ']'
I have abandoned trying with Ubuntu 9.10 and managed to compile OpenFOAM-1.5-dev on Fedora 10 but still have issues with paraFOAM (reader for the file cavity.OpenFOAM cannot be found while testing the tutorials)
Have I done something wrong or missing some package, obviously something's not right? Any ideas?
By the way, the 'wclean'-command produces:
wclean error: 'Make' directory does not exist
And have you modified the (extra?) '-' in 'ParaView3.3-cvs' in any way and if you have, what have you done exactly? I am referring to
http://www.cfd-online.com/Forums/ope...foam15dev.html
-Eero
Old   January 18, 2010, 04:40
Things here I can maybe help with:
2) I actually used the compiler that came with Fedora 12.
4) Paraview can be difficult to set up. Can you run 'glxgears'? All my problems were related to that not working.
5) Yes, that's the correct file.
6) wclean only works if there is a make directory. If you're trying to compile the whole thing then you need to do a wcleanAll. You need to do that before running Allwmake again.
I haven't actually compiled the -dev version, I may try later.
Old   March 11, 2010, 12:29
Mihir
mihir1310 is on a distinguished road
I m having the same trouble compiling a code as I add lagrangian particle classes to it . Since Im running on a cluster I may not have the access to be able to edit the wmake/linux64/general file.
You said you could manually edit the Make/linux64GccDPOpt/options file. here is my options file
# 1 "options"
# 1 "<built-in>"
# 1 "options"
EXE_INC = -I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS = -lfiniteVolume
Could you elaborate what were those changes ?
mihir1310 is offline   Reply With Quote
Old   March 12, 2010, 05:26
I strongly suggest that you add the -P option to cpp in your wmake rules, or get your system administrator to do so, otherwise you'll have to manually edit every time you use wmake!
It was either the '\' missing from the end of lines, or a tab/carriage return missing at the end of lines.
Old   September 25, 2010, 17:45
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
"-P" is a good solution!
-P: Inhibit generation of linemarkers in the output from the preprocessor. This might be useful when running the preprocessor on something that is not C code, and will be sent to a program which might be confused by the linemarkers.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   September 26, 2010, 10:24
It's been added to the 1.7 release.
Old   June 14, 2016, 11:56
elham usefi
elham usefi is on a distinguished road
Hi guys!
i had D same problem
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/elham/OpenFOAM/elham-2.4.0/applications/solvers/2
for those who have the same problem I solved it simply by adding space and backslash (\) at the end of the lines in Make/option file in EXE_INC = \ part (except for the last line)
clarkent and Lehaibmo like this.
elham usefi is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
compiling firefoam Farshad_Noravesh OpenFOAM 27 December 24, 2012 04:21
[swak4Foam] swak4foam can not be installed hugo17 OpenFOAM Community Contributions 1 September 11, 2012 05:17
OpenFoam 1.6-ext - error ./Allwmake in /src preibie OpenFOAM Installation 14 June 14, 2011 05:57
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
