Problems with Scotch
1 Attachment(s)
Dear all,
I am struggling to install OpenFOAM on a Linux 64 cluster system using system modules, in particular with Scotch. I tried OF versions 2.2.x and 3.0.x, nothing worked. I did specify the path to the system's Scotch module in etc/config/scotch.sh , just like I modified etc/config/settings.sh and etc/bashrc to tell the compiler (Intel v. 2015) to use the system's MPI (INTELMPI). Can any bright mind out there help me? (BTW this is my first post here) Many thanks, Ivan |
Quick requests, in order to diagnose the problem:
export SCOTCH_ROOT=$SCOTCH_ARCH_PATH |
I resolved the problem in the meantime - would be happy to upload my files on here if that could help someone else, but it says "invalid file" ?
Anyway, it turned out some of my modules weren't loaded in the right order. OF-3.0.x compiled normally after that, whereas OF-2.2.x bugged due to Flex. For anyone trying to compile an older OF version with a recent version of Flex, this did the trick for me: http://bugs.openfoam.org/view.php?id=1974 Thanks, Ivan |
