[swak4Foam] foam-extend-3.2 groovyBC example wont execute
Old   June 17, 2016, 09:32
Default foam-extend-3.2 groovyBC example wont execute
JFM
JFM's Avatar
John Anonymous
JFM is on a distinguished road
Send a message via Skype™ to JFM
Hello All
I have installed foam-extend-3.2 on openSuse Leap and suspect there is a problem with the installation however a review of the log does not show any components that have failed or flagged an error - the make log is attached.
The main reason causing me to think this is when I run the groovyBC example called fillingTheDam (i.e. by running blockMesh then interFoam) I receive an error related to the simpleFunctionObject as below.
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     3.2                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 3.2-334ba0562a2c
Exec     : interFoam
Date     : Jun 17 2016
Time     : 22:51:15
Host     : linux-1afo
PID      : 7679
CtrlDict : "/home/jfm/foam/jfm-3.2/swak4Foam_Examples/groovyBC/fillingTheDam/system/controlDict"
Case     : /home/jfm/foam/jfm-3.2/swak4Foam_Examples/groovyBC/fillingTheDam
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 124
    could not load libOpenFOAM.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    could not load libswakPythonIntegration.so: cannot open shared object file: No such file or directory
Create mesh for time = 0
Reading g
Reading field pd
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
Selecting turbulence model type laminar
time step continuity errors : sum local = 0, global = 0, cumulative = 0
PCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0 velocity magnitude: 0
Starting time loop
deltaT = 0.00119048
swak4Foam: Allocating new repository for sampledGlobalVariables
swak4Foam: Allocating new repository for sampledSets
--> FOAM Warning :
    From function simpleFunctionObject::simpleFunctionObject
    in file simpleFunctionObject/simpleFunctionObject.C at line 109
    'outputControlMode' not found in fillingHeight
Assuming: timeStep
--> FOAM Warning :
    in file simpleFunctionObject/simpleFunctionObject.C at line 117
    'outputInterval' not found in fillingHeight
Assuming: 1
swak4Foam: Setting default mesh
--> FOAM Warning :
    'outputControlMode' not found in maxFilling
Assuming: timeStep
--> FOAM Warning :
    'outputInterval' not found in maxFilling
Assuming: 1
--> FOAM Warning :
    'outputControlMode' not found in surfaceVel
Assuming: timeStep
--> FOAM Warning :
    'outputInterval' not found in surfaceVel
Assuming: 1
swak4Foam: Allocating new repository for sampledSurfaces
--> FOAM Warning :
    'outputControlMode' not found in surfaceSize
Assuming: timeStep
--> FOAM Warning :
    'outputInterval' not found in surfaceSize
Assuming: 1
--> FOAM Warning :
    'outputControlMode' not found in normalizedVolume
Assuming: timeStep
--> FOAM Warning :
    'outputInterval' not found in normalizedVolume
Assuming: 1
--> FOAM Warning :
    'outputControlMode' not found in getG
Assuming: timeStep
--> FOAM Warning :
    'outputInterval' not found in getG
Assuming: 1
--> FOAM Warning :
    From function functionObjectListProxy::functionObjectListProxy
    in file functionObjectProxy/functionObjectListProxy/functionObjectListProxy.C at line 98
    For getG the 'readDuringConstruction'-variable  is ignored because this concrete class does not allow  constructing the functionObjects during construction
--> FOAM Warning :
    From function solvePDECommon::read(const dictionary& dict)
    in file solvePDECommon.C at line 158
    If you want the unsteady run to use relaxation set 'relaxUnsteady true;' in "::tracer"
swak4Foam: Allocating new repository for sampledMeshes
Manipulated field tracer in 2268 cells with the expression "0"
--> FOAM Warning :
    'outputControlMode' not found in doWithPython
Assuming: timeStep
--> FOAM Warning :
    'outputInterval' not found in doWithPython
Assuming: 1
--> FOAM Warning :
    For doWithPython the 'readDuringConstruction'-variable  is ignored because this concrete class does not allow  constructing the functionObjects during construction
Time = 0.00119048
MULES: Solving for alpha1
Liquid phase volume fraction = 0  Min(alpha1) = 0  Max(alpha1) = 1
--> FOAM FATAL ERROR:
This specialisation is not implemented
    From function ExpressionResult::calcIsSingleValueInternal<bool>()
    in file ExpressionResult/ExpressionResult.C at line 373.
FOAM exiting
Any assistance will be greatly appreciated
Regards
John
JFM is offline   Reply With Quote
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
