[OpenFOAM.com] v1606+ Compilation error - ptscotch.h not found |
Tommaso
Rep Power: 8 ![]() |
Hi everyone,
I wonder if anyone could help me....I've just downloaded the new OF version 1606 and I'm trying to compile it. Unluckily I got the following error: Code:
/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/src/parallel/decompose/ptscotchDecomp wmake libso ptscotchDecomp /home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/src/parallel/decompose/ptscotchDecomp wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file ptscotchDecomp.C could not open file ptscotch.h for source file ptscotchDecomp.C due to No such file or directory g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent -I/usr/lib/openmpi/include/openmpi/opal/mca/event/libevent2021/libevent/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread -I/include -I/home/tommaso/App/OpenFOAM/ThirdParty-v1606+/platforms/linux64GccInt32/scotch_6.0.3/include/openmpi-system -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/src/OpenFOAM/lnInclude -I/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/src/OSspecific/POSIX/lnInclude -fPIC -c ptscotchDecomp.C -o /home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o ptscotchDecomp.C:214:26: fatal error: ptscotch.h: No such file or directory compilation terminated. /home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/wmake/rules/General/transform:8: recipe for target '/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o' failed make: *** [/home/tommaso/App/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o] Error 1 My libraries/compilers etc are all up to date. I'm not much of an expert on this sort of things, so I hope to get some help. Cheers, Tommaso Last edited by wyldckat; September 9, 2016 at 18:52. Reason: Added [CODE][/CODE] markers |
Stefan
Rep Power: 9 ![]() |
Hey Tommaso,
just got the same problem doing the installation on a cluster of the university. Just got the advise to check whether the "bashrc" file contains the right "standard-Compiler- and MPI-version" which is supposed from the admins. So i changed the compiler to the "Icc" one by changing the code of the bashrc """ #- Compiler: # WM_COMPILER = Gcc | Gcc45 | Gcc46 | Gcc47 | Gcc48 | Gcc49| Clang | Icc #######export WM_COMPILER=Gcc export WM_COMPILER=Icc """ and the MPI-Version to "SYSTEMOPENMPI" """ export WM_MPLIB=SYSTEMOPENMPI """ The installation is running now since 3 hours and didn't crash like the last times. Fingers crossed it runs through all the steps... I hope that may help you. Regards Stefan |
Stefan
the installation failed also, again at the ptscotch.h file. I will talk to the admins and let you know. Regards Stefan |
Tommaso
Hello Stephan,
thanks for you reply and sorry for the delay. I had to put the project in the backburner for a while and I resumed it not long ago. Finally I managed to get everything working just by installing ptscotch with: sudo apt-get install ptscotch eveything compiled and now it's working! Thanks again! |
Retired Super Moderator
Bruno Santos
Rep Power: 126 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: Sorry for the delay in responding to this, but it was only fairly recently that I managed to document the detailed installation steps for installing OpenFOAM+ v1606+ on a few systems: https://openfoamwiki.net/index.php/I...AM%2B-v1606%2B
Nonetheless, there is no clear indication in the details you've all provided, in order to diagnose why "ptscotch" is not getting built properly. For those who are still having problems with this, please run the following commands: Code:
cd $WM_THIRD_PARTY_DIR ./Allwmake > log.make 2>&1 gzip < log.make > log.make.gz edit: I forgot to mention that if you downloaded the package "ThirdParty-v1606+.tgz" soon after the release of v1606+, it was updated again a few days later to fix one or two issues with the build scripts. That might have been the origin of the very first reported issue here.
Rosemarie Meuer
Rep Power: 0 ![]() |
I am having the same problem with OpenFoam16.12. I have attached the error messages from ptscotch.
Victor Eijkhout
Scotch & Ptscotch...
I installed scotch/ptscotch myself and then added include & lib directories to the compiler. That worked for me. In my case that meant editing Code:
wmake/rules/linux64Gcc/c++ |
Display Modes | |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 16:54 |
