3.0.x ParaView compiling error Fedora 24
I am trying to install openfoam 3 in fedora 24 using the following link: https://openfoamwiki.net/index.php/I...M-3.0.x/Fedora but when I run the makeparaview4 command I get the following error: ----------------------------------------------------------------------------------------------------- CMake Error at VTK/CMake/vtkCompilerExtras.cmake:47 (if): if given arguments: "gcc: error: ARGS: No such file or directory gcc (GCC) 6.1.1 20160621 (Red Hat 6.1.1-3) ----------------------------------------------------------------------------------------------------- it seems the current gcc comiler and cmake does not go together! can anyone help me with this? |
I found a solution and I m gonna post it just in case:
there are two files "vtkCompilerExtras.cmake" and "GenerateExportHeader.cmake" which you can find by "find THIRDPARTY_FOLDER -name xxx". open both of them and change the following lines: string (REGEX MATCH "[345]\\.[0-9]\\.[0-9]*" by adding simply a "6" after "345" so that the line looks like the following: string (REGEX MATCH "[3456]\\.[0-9]\\.[0-9]*" |
Quick answer: Many thanks for posting the solution you've found. I've copy-paste-adapted the instructions on the wiki based on your findings and this bug report: http://bugs.openfoam.org/view.php?id=2098
Instructions are now here: https://openfoamwiki.net/index.php/I...dora#Fedora_24 |
Thanks thanks thanks a lot
This continues in OpenFOAM 4.1 with Ubuntu 17.10 with default gcc version 7.x, therefore, I follow your instructions and just added: "7" after "3456" in both the files and surprisingly it works! Thanks :)
Tip to other users, you can check gcc version by: gcc --version |
samething for OpenFOAM v1606+ in Ubuntu 18.04. Needs to replace 3-6 by 3-7 for gcc version greater than 6.*. Thanks! |
Cool!
Just a note: no need to look for those files and line numbers, since ccmake clearly points those out. E.g. : Code:
CMake Error at VTK/CMake/GenerateExportHeader.cmake:178 (if): Just make sure you go to the source paraview dir, not the one you are building from. Also, I had to go up to number 8 now. I guess the most elegant thing is to write "3-8", intead of "3456768". ( BTW I am trying to compile version 4.4 of paraview, since most recent ones won't run in my current system --- openGL issues.) |
Thanks! As a matter of fact, I did succeed in compiling ParaView v5.3. I know they took away legacy openGL about one year ago, I was conservative in choosing 5.3 since I was not sure which was the latest version. It's quite easy to choose the right setting with e.g. ccmake. Just go to the "VTK_RENDERING_BACKEND" option and change it. After some configuration steps, a Makefile is generated. The compilation is not too long if run in parallel ("make -j 4", or as much cores as you have available). My paraview is independent of openfoam. I usually run "touch cc.openfoam; paraview cc.openfoam & ". A note: the resulting paraview executable cannot be moved from its folder ! Just make an alias to it. In my case: "alias paraview='~/Downloads/paraview/bin/paraview' " (yup, that's where it ended). Also, I am on manjaro linux -- this sort of procedure should work on any linux system, I think. |
