[foam-extend.org] core dumped for foam extended 3.2 on Ubuntu 16.04 |
September 15, 2016, 08:26 |
Janry
Rep Power: 10 |
Hi Foamers,
Recently I've install the foam -extended 3.2 on Ubuntu 16.04. However, when I run the cases and tutorials, all of them crashed with no reason core dumped. For example: Code:
uqjqi@uqjqi:~/Desktop/work/11_09_2016_Stage$ icoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : icoFoam Date : Sep 15 2016 Time : 22:13:06 Host : uqjqi PID : 12610 CtrlDict : "/home/uqjqi/Desktop/work/11_09_2016_Stage/system/controlDict" Case : /home/uqjqi/Desktop/work/11_09_2016_Stage nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 1.653947e-06 Floating point exception (core dumped) and Code:
uqjqi@uqjqi:~/Desktop/work/11_09_2016_Stage$ steadyCompressibleMRFFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : steadyCompressibleMRFFoam Date : Sep 15 2016 Time : 22:12:55 Host : uqjqi PID : 12606 CtrlDict : "/home/uqjqi/Desktop/work/11_09_2016_Stage/system/controlDict" Case : /home/uqjqi/Desktop/work/11_09_2016_Stage nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 1.653947e-06 Floating point exception (core dumped) can anybody help me out? Thanks! Janry |
September 17, 2016, 08:39 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Your description is a bit inconsistent, because you mentioned that the tutorial cases crash, but then you provide the output for a case that is not part of the tutorials.
Please provide the output you get when you run one of the foam-extend 3.2 tutorials cases. And/or please provide the file "system/controlDict", in which I'm guessing that you have a "libs" entry there that is forcing to load libraries that were last built for another version of foam-extend or OpenFOAM.
September 17, 2016, 08:49 |
#3 | |
Janry
Rep Power: 10 |
Hi Bruno, Thanks for your reply! The following is the tutorial for the axialTurbin_mixingPlane: Code:
uqjqi@uqjqi:~/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane$ ./Allrun Running blockMesh on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : transformPoints -scale (1 20 1) Date : Sep 17 2016 Time : 22:44:15 Host : uqjqi PID : 7592 CtrlDict : "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane/system/controlDict" Case : /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Scaling points by (1 20 1) Writing points into directory "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane/constant/polyMesh" /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : transformPoints -cylToCart ((0 0 0) (0 0 1) (1 0 0)) Date : Sep 17 2016 Time : 22:44:15 Host : uqjqi PID : 7593 CtrlDict : "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane/system/controlDict" Case : /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Writing points into directory "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane/constant/polyMesh" Running setSet on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane Running setsToZones on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane Running MRFSimpleFoam on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane uqjqi@uqjqi:~/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane$ Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : MRFSimpleFoam Date : Sep 17 2016 Time : 22:44:16 Host : uqjqi PID : 7599 CtrlDict : "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane/system/controlDict" Case : /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Floating point exception (core dumped) Another is the axialTurbin_ggi: Code:
uqjqi@uqjqi:~/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi$ ./Allrun Running blockMesh on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : transformPoints -scale (1 20 1) Date : Sep 17 2016 Time : 22:48:16 Host : uqjqi PID : 7811 CtrlDict : "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi/system/controlDict" Case : /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Scaling points by (1 20 1) Writing points into directory "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi/constant/polyMesh" /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : transformPoints -cylToCart ((0 0 0) (0 0 1) (1 0 0)) Date : Sep 17 2016 Time : 22:48:16 Host : uqjqi PID : 7812 CtrlDict : "/home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi/system/controlDict" Case : /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Floating point exception (core dumped) Running setSet on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi Running setsToZones on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi Running MRFSimpleFoam on /home/uqjqi/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi Janry |
September 17, 2016, 09:28 |
Bruno Santos
Rep Power: 128 |
Quick answer: Please run this command:
ldd $(which MRFSimpleFoam) In addition, the output of the following command is also useful: Code:
export |
September 17, 2016, 22:26 |
#5 | |
Janry
Rep Power: 10 |
Thanks for your reply. The following is the output when running the ldd $(which MRFSimpleFoam): Code:
uqjqi@uqjqi:~/foam/foam-extend-3.2/tutorials/incompressible/MRFSimpleFoam/axialTurbine_ggi$ ldd $(which MRFSimpleFoam) linux-vdso.so.1 => (0x00007f0f492e1000) libincompressibleRASModels.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libincompressibleRASModels.so (0x00007f0f48d85000) libincompressibleTransportModels.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libincompressibleTransportModels.so (0x00007f0f48b03000) libfiniteVolume.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libfiniteVolume.so (0x00007f0f46c03000) liblduSolvers.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/liblduSolvers.so (0x00007f0f4699e000) libfoam.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libfoam.so (0x00007f0f45c58000) libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f0f45a29000) librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f0f45820000) libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f0f4549e000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f0f45195000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f0f44f7e000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0f44bb5000) libincompressibleTurbulenceModel.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so (0x00007f0f4495a000) libmeshTools.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libmeshTools.so (0x00007f0f444ff000) libmpi.so.1 => /home/uqjqi/foam/foam-extend-3.2/ThirdParty/packages/openmpi-1.6.5/platforms/linux64GccDPOpt/lib/libmpi.so.1 (0x00007f0f4415f000) libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f0f43f44000) libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f0f43d27000) /lib64/ld-linux-x86-64.so.2 (0x000055c53f341000) libdecompositionMethods.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/libdecompositionMethods.so (0x00007f0f43afb000) liblagrangian.so => /home/uqjqi/foam/foam-extend-3.2/lib/linux64GccDPOpt/liblagrangian.so (0x00007f0f438da000) libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007f0f436cf000) libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f0f434cb000) Janry |
September 18, 2016, 16:17 |
Bruno Santos
Rep Power: 128 |
Quick answer: ldd did not show anything out of the ordinary. It's linking to "libnuma.so", which I wasn't familiar with, but I guess it's due to the machine you have, namely if you have a multi-socket workstation/server.
Nonetheless, you forgot to also post the output from the export command that I asked for. If the output is too long, you can run: Code:
export > log.export gzip < log.export > log.export.gz |
September 18, 2016, 19:53 |
#7 | |
Janry
Rep Power: 10 |
Hi Bruno, Thanks for your reply. The export output is attached, please see the attachment. log.export.gz Thanks! Janry |
September 26, 2016, 18:34 |
Bruno Santos
Rep Power: 128 |
Quick answer: I took a look into this during this past weekend and I wasn't able to figure out a reason for this problem that you're getting.
My best guess right now is that there is something installed in the user folders. Try the following commands, to see if they list any suspicious libraries of applications: Code:
ls -l $FOAM_USER_LIBBIN ls -l $FOAM_USER_APPBIN Although, now that I think about it, what exact installation instructions did you follow? And did you make any changes besides what the instructions indicated? |
September 26, 2016, 21:19 |
#9 | |
Janry
Rep Power: 10 |
Hi Bruno, Thanks for your reply. Yes I think I use multiple gcc version when I installed it. Because the default gcc version for 16.04 is 5.4, but the SIG density based solver requires gcc 4.6 to compile it. So, after I install foam extend 3.1, I shifted to gcc 4.6 to compile the SIG density based solver, then, failed. I think all the foam extend or the third party solvers should be installed within constant version of gcc and g++... Thanks very much! Janry |
September 27, 2016, 16:39 |
#10 | |
Bruno Santos
Rep Power: 128 |
Anyway, it's excellent that you've managed to pick up the origin of the problem! |
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS | JMosiezny | OpenFOAM Installation | 15 | December 9, 2017 08:20 |
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) | Milan2013 | OpenFOAM Installation | 23 | April 20, 2017 05:49 |
[foam-extend.org] foam-extend 3.2 on Ubuntu 12.04, Floating point exception for tutorials | arsalan.dryi | OpenFOAM Installation | 7 | November 14, 2016 17:33 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
