4.0: Paraview 5.0 wont run after reinstall
Helo everyone!
I can't get paraview to run after a reinstall. The error i get is : Code:
FATAL ERROR: ParaView reader module libraries do not exist Code:
./Allwmake : PV_PLUGIN_PATH not valid - it is unset I'm a bit lost since I've tried purging openFoam and reinstalled as a fresh install several times in several fashions and everything is working fine except for paraview. A few threads already discussed this issue, but must of them cover older versions of OpenFOAM and most of the suggested commands don't seem to work anymore. Any help would be appreciated! Cheers, Pedro |
uhhh... apparentely you need to close and open a new terminal before paraFoam works. I can't believe i spent the last three hours panicking over this without ever closing my terminal once.
I apologize for the stupidity :( |
Greetings Pedro,
Don't worry, it can happen to anyone. Can you please indicate which installation instructions you've followed? I ask this so that this kind of situation doesn't happen again. Best regards, Bruno |
sure!
i tried following this: Code:
cd ~/OpenFOAM from this thread. the first command seems to be outdated, so i just navigated to /opt/ folder and removed (rm -rf) both the paraview and parafoam folders. Alternatively, i just ran: Code:
sudo apt-get purge openFoam* Code:
sudo apt-get -y install openfoam4 |
