v1606+ Installation on Windows 7
Never used OpenFOAM before. Tried installing on a Windows 7 laptop. Installation seems to work, and I can start with OpenFOAM_start desktop icon. A command prompt appears allowing input, and I could change directory to workingDir. BUT, the issue is that I cannot locate the tutorials. The \Opt folder does NOT exist after installation.
In the FAQ's on openfoam.com it says:
\Esi\OpenFOAM\1066\Scripts ... where I guess the installed files are actually located PLEASE ADVISE. THANK YOU! |
Sorry, I moved your thread but forgot to give you an answer :(
Please check this thread: http://www.cfd-online.com/Forums/ope...tutorials.html |
Hi guys, I'm new in open form 1606 installed on widows. I tried running the openfoam_start in Dos environment..it gives me Error response from daemon: failed to start containers of_plus_1606..Pls what should I do?
I installed it on windows 7 laptop. |
Or please provide the full text before and after that line, to get a better perception of the context in which the error occurred. |
