-   OpenFOAM Installation (https://www.cfd-online.com/Forums/openfoam-installation/)
-   -   [foam-extend.org] foam-extend 3.2 on Ubuntu 12.04, Floating point exception for tutorials (https://www.cfd-online.com/Forums/openfoam-installation/179921-foam-extend-3-2-ubuntu-12-04-floating-point-exception-tutorials.html)
arsalan.dryi November 10, 2016 19:26
1 Attachment(s)
Dear Foamers,
Recently I've installed foam extend 3.2 on Ubuntu 12.04, a long time installation procedure!
But I get floating point exception (core dumped) when I run tutorial cases in the surfaceTracking folder!
Also I'd installed foam-extend 3.1 a long time ago and I didn't have this problem!
For example, here is the results of hydrofoil tutorial after Allrun executation:
log.makeFaMesh:
| \\      /  F ield        | foam-extend: Open Source CFD                    |
|  \\    /  O peration    | Version:    3.2                                |
|  \\  /    A nd          | Web:        http://www.foam-extend.org        |
|    \\/    M anipulation  | For copyright notice see file Copyright        |
Build    : 3.2-a4e7bf3b15c0
Exec    : makeFaMesh
Date    : Nov 11 2016
Time    : 03:34:02
Host    : arsalan-VPCSE2EFX
PID      : 6655
CtrlDict : "/home/arsalan/foam/arsalan-3.2/run/hydrofoil/system/controlDict"
Case    : /home/arsalan/foam/arsalan-3.2/run/hydrofoil
nProcs  : 1
SigFpe  : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Floating point exception (core dumped)
log.interTrackFoam:
Exec    : interTrackFoam
Date    : Nov 11 2016
Time    : 03:34:02
PID      : 6657
nProcs  : 1
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
For more detailed information, here is the result of "ldd $(which interTrackFoam)" command:
        linux-vdso.so.1 =>  (0x00007ffe944ec000)
        libfreeSurface.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libfreeSurface.so (0x00007fd32c97e000)
        libdynamicFvMesh.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libdynamicFvMesh.so (0x00007fd32c618000)
        libdynamicMesh.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libdynamicMesh.so (0x00007fd32c1e8000)
        libmeshTools.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libmeshTools.so (0x00007fd32bd8f000)
        libfiniteVolume.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libfiniteVolume.so (0x00007fd329e8d000)
        libfiniteArea.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libfiniteArea.so (0x00007fd329837000)
        liblduSolvers.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/liblduSolvers.so (0x00007fd3295d3000)
        libmesquite.so.0 => /home/arsalan/foam/foam-extend-3.2/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc49DPOpt/lib/libmesquite.so.0 (0x00007fd32921d000)
        libfoam.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libfoam.so (0x00007fd3284d5000)
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fd3282d1000)
        librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fd3280c9000)
        libstdc++.so.6 => /home/arsalan/foam/foam-extend-3.2/ThirdParty/packages/gcc-4.9.2/platforms/linux64Gcc49DPOpt/lib64/libstdc++.so.6 (0x00007fd327d9d000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fd327aa1000)
        libgcc_s.so.1 => /home/arsalan/foam/foam-extend-3.2/ThirdParty/packages/gcc-4.9.2/platforms/linux64Gcc49DPOpt/lib64/libgcc_s.so.1 (0x00007fd32788b000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fd3274cd000)
        libtetFiniteElement.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libtetFiniteElement.so (0x00007fd326e92000)
        libtetMotionSolver.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libtetMotionSolver.so (0x00007fd326c28000)
        libdecompositionMethods.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libdecompositionMethods.so (0x00007fd3269fd000)
        libsolidBodyMotion.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libsolidBodyMotion.so (0x00007fd3267bd000)
        libfvMotionSolver.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libfvMotionSolver.so (0x00007fd3263d9000)
        libRBFMotionSolver.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/libRBFMotionSolver.so (0x00007fd3261c7000)
        liblagrangian.so => /home/arsalan/foam/foam-extend-3.2/lib/linux64Gcc49DPOpt/liblagrangian.so (0x00007fd325fa6000)
        libmpi.so.1 => /home/arsalan/foam/foam-extend-3.2/ThirdParty/packages/openmpi-1.6.5/platforms/linux64Gcc49DPOpt/lib/libmpi.so.1 (0x00007fd325c06000)
        libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fd3259ef000)
        /lib64/ld-linux-x86-64.so.2 (0x00007fd32cde1000)
        libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fd3257d2000)
        libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007fd3255cf000)
Also the attachment contains result of "export" command.
Finally, the installation procedure which I've passed is as follows:
1)
sudo apt-get update
2)
sudo apt-get install git-core build-essential binutils-dev flex \
bison zlib1g-dev qt4-dev-tools libqt4-dev libncurses5-dev \
libxt-dev rpm mercurial graphviz python python-dev
3)
cd ~/foam/foam-extend-3.2
echo export WM_COMPILER=Gcc49 >> etc/prefs.sh
echo export WM_THIRD_PARTY_USE_GCC_492=1  >> etc/prefs.sh
echo export compilerInstall=FOAM >> etc/prefs.sh
source etc/bashrc
4)
cd ~
mkdir foam
cd foam
git clone git://git.code.sf.net/p/foam-extend/foam-extend-3.2 foam-extend-3.2
5)
source etc/bashrc
echo "alias fe32='source \$HOME/foam/foam-extend-3.2/etc/bashrc'" >> $HOME/.bashrc
6)
export QT_BIN_DIR=/usr/bin/qmake-qt4
echo "export QT_BIN_DIR=$QT_BIN_DIR" >> etc/prefs.sh
7)
export CUDA_ARCH=sm_30
echo "export CUDA_ARCH=sm_30" >> etc/prefs.sh
8)
./Allwmake.firstInstall
Sorry for the long post, but I tried to give a detailed information about my problem for a better solution.
Any help will be appreciated,
Regards,
Arsalan.
wyldckat November 13, 2016 12:52
Quick answer: This seemed fairly familiar... the following thread accounts something very similar: http://www.cfd-online.com/Forums/ope...u-16-04-a.html
Many thanks for all of the details! Nonetheless, my best guess is that the foam-extend 3.1 was still partially loaded in when you build foam-extend 3.2?
Did you start with a clean shell environment (no OpenFOAM/foam-extend environment loaded in)?
Have you tried the simpler tutorial cases? For example "incompressible/icoFoam/cavity".
In addition, what do the following commands give you when you have foam-extend 3.2 environment loaded?
gcc --version
g++ --version
And do you really have the CUDA compiler stack installed?
arsalan.dryi November 13, 2016 18:04
Dear Bruno,
Thanks for your replay. About the problem,
Mmm, I don't remember this, usually I use a clean shell environment for new purposes, but I can't say this with certainty.
I tried them after your suggestion, some of them works likes:
cavity (icoFoam), damBreak (interFoam), sloshingTank2D (interDyMFoam), sloshing2D and ramp (interTrackFoam)
and some not, for example:
mixerVessel2D (MRFInterFoam), hydrofoil (interTrackFoam), bubble2D (bubbleInterTrackFoam).
gcc --version
g++ --version
Both of them says the same version of 4.9.2 for gcc and g++.
Nope, just put this step since it's set to optionally in the wiki installation page.
Thanks for your time and helps.
Regards,
Arsalan.
wyldckat November 13, 2016 18:48
Hi Arsalan,
It feels like something is missing in your description or maybe I'm not seeing a clue that is already present in the details you've given.
A few more questions:
  1. Did you need to run Allwmake.firstInstall more than once?
  2. How much RAM does your machine have? When in doubt, you can run:
    free -h
    • Along with this, how many cores? You can check by running:
      lscpu
      E.g. the following lines tells us the main details about core distribution:
      CPU(s):                4
      On-line CPU(s) list:  0-3
      Thread(s) per core:    2
      Core(s) per socket:    2
      Socket(s):            1
      NUMA node(s):          1
  3. When you described the installation steps, did you really do steps #3 and #4 in that order? Or did you do #4 before #3?
  4. Did you notice or have any other problems when trying to build foam-extend 3.2?
I ask these questions, because any of these can have a considerable impact on the resulting build as well, because the system's GCC may have been used to build at least part of foam-extend, which would conflict with the remaining build that was done with GCC 4.9.
Best regards,
Bruno
arsalan.dryi November 14, 2016 03:05
Hi Bruno,
Many thanks for your fast replay.
Originally Posted by wyldckat (Post 625197)
Hi Arsalan,
No I ran it only once, maybe I should run it for a second time if helps?
free -h
Actually --h is an invalid option for free in my machine, the results of free --m (m for show output in MB) is as follows:
            total      used      free    shared    buffers    cached
Mem:          5885      1840      4045          0        120        807
-/+ buffers/cache:        912      4973
Swap:        5243          0      5243
lscpu
Well, the output of lscpu is shown below:
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                4
Socket(s):            1
NUMA node(s):          1
Vendor ID:            GenuineIntel
CPU family:            6
Model:                42
Stepping:              7
CPU MHz:              2801.000
BogoMIPS:              5587.04
Virtualization:        VT-x
L1d cache:            32K
L1i cache:            32K
L2 cache:              256K
L3 cache:              4096K
NUMA node0 CPU(s):    0-3
I did step #3 before step #4, I'm sure about this. And I didn't have other problems at the building procedure.
Anyway, I'm ready for starting a new clean installation if only this could fix the problem.
Thanks in advance.
Regards,
Arsalan.
wyldckat November 14, 2016 17:16
Quick answer: I don't see any major limitations regarding RAM and CPU, therefore I'm guessing that the problem was because step #3 was done before #4, which resulted in the problem you're having right now.
I'm sad to say that it does seem to be best that you start over the build from a clean installation. It's safer that way.
arsalan.dryi November 14, 2016 17:27
Dear Bruno,
Okay, is there anything that I should do for a new clean installation?! Except for starting with a clean shell environment!
Many thanks for your endless helps, it's really warming for us to have you in the forum.
Regards,
Arsalan.
wyldckat November 14, 2016 17:33
I wrote about that a few years ago here: http://openfoamwiki.net/index.php/FA...ve_OpenFOAM.3F
