[foam-extend.org] foam-extend 3.1 installation problems: ParaView 4.0.1 RPM won't install |
February 1, 2017, 16:08 |
Kay
Rep Power: 10 |
I am new to OpenFOAM. I run into an error during installation. I would be glad if someone would help me resolve it. Your help is greatly appreciates. Please see error file attached. Sincerely. |
February 1, 2017, 21:39 |
khedar
Rep Power: 9 |
1. You should be asking this in OpenFOAM Installation forum https://www.cfd-online.com/Forums/op...-installation/
2. I don't see any errors in the attached file. It installs paraview perfectly(part of third party packages) it seems. |
February 2, 2017, 05:30 |
#3 | |
Kay
Rep Power: 10 |
Thank you for your prompt response. In the last lines is an error. Its says RPM build errors (please see below). I am not sure how this RPM files is generated. Sincerely, RPM build errors: Installing package: ParaView-4.0.1 Uninstalling ParaView-4.0.1 using RPM: ParaView-4.0.1-linux64GccDPOpt.x86_64 Installing ParaView-4.0.1 using RPM file: /home/kumahor/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm Done installing package |
February 20, 2017, 18:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question @Kay: Which Linux Distribution are you using?
Because the error message is not clear as to why it was not able to build ParaView, therefore we need to at least know how we can try and reproduce the same error.
March 31, 2017, 07:38 |
Kay
Rep Power: 10 |
Hello Bruno,
sorry I missed your reply. Really sorry. I was using Ubuntu 16.04.1. This was probably the problem with libraries. I changed now with Openfoam 2.4 and this could compile and I could also use paraview. Thanks a lot. S. |
Display Modes | |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
Installation problems about Paraview and PV3foamreader | clark_liang | OpenFOAM Installation | 1 | January 12, 2009 07:05 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 14:29 |
