October 5, 2018, 03:21 |
Problem installing v1806
Jorge Molines
Rep Power: 13 |
Hi!
I was working nicely with OpenFOAM v1706 but I tried to move to v1806 and I have some errors. When I write source ~/OpenFOAM/OpenFOAM-v1806/etc/bashrc I obtain the following error: No completion added for /home/jorge/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin ... incorrect platform, or not yet compiled? Although the error, I made the installation by adding to the bashrc the line source ~/OpenFOAM/OpenFOAM-v1806/etc/bashrc and I obtained a critical error: Software Version Location ------------------------------------------------------------------------------- flex 2.6.0 /usr/bin/flex gcc 5.4.0 /usr/bin/gcc g++ 5.4.0 /usr/bin/g++ gzip 1.6 /bin/gzip tar 1.28 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for troubleshooting. Done Finally, if I try to run any case such as Pitzdaily, OpenFOAM does not recognize any of the orders such as blockMesh, setFields.... Could anyone help me? Thanks in advance |
October 7, 2018, 06:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings jormollo,
Requests so that anyone can try and help you with this:
For future questions, please keep in mind the instructions given on this thread: How to give enough info to get help Best regards, Bruno
October 10, 2018, 09:48 |
Jorge Molines
Rep Power: 13 |
Thanks Bruno, I will keep yout recommendations in mind. Answering to your questions:
1. I was following the instructions provided at www.openfoam.com (both for the pre-requisites and the build guide). 2. The version of Ubuntu is 16.04 in a Virtual Machine VM VirtualBox 3. I did not change any of the instructions. I was struggling more and more and finally I succesfully installed OpenFoam 1806 in Ubuntu 18.04. When I first tried the installation on Ubuntu 18.04 with only 1GB of RAM, I could not install OpenFOAM 1806 (I had exactly the same problem as in Ubuntu 16.04). However, when I put 2GB of RAM, the installation was succesfully completed. Regards, Jorge. |
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! | omid20110 | OpenFOAM Installation | 6 | August 1, 2016 11:20 |
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison | lxwd | OpenFOAM Community Contributions | 1 | March 20, 2016 16:03 |
Problem with installing OpenFOAM 2.0.X | mohsen.boojari | OpenFOAM Installation | 3 | February 3, 2016 11:41 |
Problem installing OpenFOAM-1.6-ext on Ubuntu 14.04 | afrotimy | OpenFOAM Installation | 4 | October 4, 2014 11:36 |
Problem in installing OpenFOAM-ParaView-0.1.1-1.x86_64 | hassan5565 | OpenFOAM Installation | 1 | August 5, 2014 13:05 |
