[foam-extend.org] How can I install PARAVIEW on foam-extend 3.1 ? |
July 21, 2014, 13:56 |
stevem garcia
Rep Power: 11 |
How can I install PARAVIEW on foam-extend 3.1 ? Like openfoam... typing "paraFoam" to open paraview...
July 21, 2014, 19:41 |
paraView and foam-extend-3.1 (problem)
stevem garcia
Rep Power: 11 |
I installed the foam-extend-3.1. But after running a tutorial case, I found this problem. I believe the ParaView was not installed. Could someone tell me how I can install it. Sorry to ask in this area of posting, but nobody in the other posts know answer me this. Thanks for attention friends!
Screenshot from 2014-07-21 20:07:19.jpg |
July 22, 2014, 03:12 |
error message suggests you to install paraview. You can do it as usual in Ubuntu, either using apt-get, or synaptic, or 'Software center'. |
July 22, 2014, 03:20 |
Rep Power: 18 |
Have you included the line for OpenFOAM in your .bashrc as mentioned on the installation page?
July 22, 2014, 21:08 |
"ParaFoam" does not open on foam-extend 3.1
stevem garcia
Rep Power: 11 |
On my computer I have installed foam-extend-3.1. However, paraview doesn't open. This is my output message from the terminal:
a@a-Aspire-V3-571:~/foam/foam-extend-3.1/tutorials/incompressible/icoFoam/cavity$ paraFoam created temporary 'cavity.OpenFOAM' /home/a/foam/foam-extend-3.1/bin/paraFoam: line 142: paraview: command not found Screenshot from 2014-07-22 22:02:31.jpg When I type ./AllMake.stage4, I got this error: Code:
a@a-Aspire-V3-571:~/foam/foam-extend-3.1/ThirdParty$ ./AllMake.stage4 This system rpm command: rpm --force-debian ======================================== Starting ThirdParty AllMake: Stage4 ======================================== Using system installed QT WARNING: WARNING: Skipping the installation of ParaView-4.0.1. WARNING: Please make sure the QT_BIN_DIR environment variable properly WARNING: initialized in the file prefs.sh or prefs.csh WARNING: The command $QT_BIN_DIR/qmake needs to be valid WARNING: ======================================== Done ThirdParty AllMake: Stage4 ======================================== Someone knows how can I solve it? Best Regards, Steven |
July 22, 2014, 21:40 |
stevem garcia
Rep Power: 11 |
Im a beginer, can you give me the steps? thanks
July 22, 2014, 22:02 |
stevem garcia
Rep Power: 11 |
If I install paraView out of foam-extend this folder, ie install regardless of foam-extend as if it had not installed foam-extend on my computer work? Or should I install through the files contained in ThirdParty? If I can install by this way (and if it is easier this way), perhaps it would be better, instead of trying to solve this problem so I posted, because may be too difficult to solve.
July 23, 2014, 02:27 |
Hassan Adel
Rep Power: 12 |
Below are build instructions for Ubuntu 14.04.
These instructions assume that you install in the default location, which is ~/foam/ . Create this folder with: cd ~ mkdir foam * Obtain and unpack source code (if you read this, you probably already have): The recommended way is to get the source code through git source code management system. This way, you can get updates and bugfixes easily by running "git pull". To install into the default location run: cd ~/foam git clone git://git.code.sf.net/p/openfoam-extend/foam-extend-3.1 Alternatively, you can download a snapshot (.tgz) of the source code from: http://sourceforge.net/projects/open...am-extend-3.1/ * Update your Ubuntu installation: sudo apt-get update sudo apt-get upgrade * Install required packages: sudo apt-get install git-core build-essential binutils-dev flex \ zlib1g-dev qt4-dev-tools libqt4-dev libncurses5-dev libiberty-dev \ libxt-dev rpm mercurial graphviz openmpi-bin libopenmpi-dev cmake * For Ubuntu 14.04, you need to customize some of the ThirdParty packages in order to enable the usage of system-provided packages, and to enable the compilation of other, like bison-2.7. Here is a list of sed commands that will do just that. You can copy/paste the following block of commands in a control terminal in order to make the necessary adjustments. You will need to be located at the root of your foam-extend-3.1 installation for those commands to work. ################################################## ################## # # Create a prefs.sh file cp etc/prefs.sh-EXAMPLE etc/prefs.sh # Use openmpi 1.6.5 as supplied by Ubuntu 14.04 sed -i s/"#export WM_MPLIB=SYSTEMOPENMPI"/"export WM_MPLIB=SYSTEMOPENMPI"/g etc/prefs.sh sed -i s/"#export OPENMPI_DIR=path_to_system_installed_openmpi"/"export OPENMPI_DIR=\/usr"/g etc/prefs.sh sed -i s/"#export OPENMPI_BIN_DIR=\$OPENMPI_DIR\/bin"/"export OPENMPI_BIN_DIR=\$OPENMPI_DIR\/bin"/g etc/prefs.sh # Use Qt 4.8.6 as provided by Ubuntu 14.04 sed -i s/"#export QT_DIR=path_to_system_installed_qt"/"export QT_DIR=\/usr"/g etc/prefs.sh sed -i s/"#export QT_BIN_DIR=\$QT_DIR\/bin"/"export QT_BIN_DIR=\$QT_DIR\/bin"/g etc/prefs.sh # Use cmake 2.8.12.2 as provided by Ubuntu 14.04 sed -i s/"( rpm_make -p cmake"/"#( rpm_make -p cmake"/g ThirdParty/AllMake.stage1 # Compile and install bison-2.7 from the ThirdParty packages. sed -i 0,/"#( rpm_make -p bison-2.7"/s//"( rpm_make -p bison-2.7"/ ThirdParty/AllMake.stage1 # ################################################## ################## * Set environment variables: cd ~/foam/foam-extend-3.1 . etc/bashrc Optionally, set environment variable for compiling Cuda solvers, for example (replace "sm_30" with value according to your GPU architecture): export CUDA_ARCH=sm_30 * Compile: ./Allwmake.firstInstall * Create user directory: mkdir -p $FOAM_RUN And you are ready to start.
H.Elsheshtawy |
July 23, 2014, 04:05 |
#9 |
Rep Power: 18 |
I don't use OF-extend, so I can't really help there.
Paraview comes with the vanilla OF distribution, you might be able to use that instead. |
July 23, 2014, 09:26 |
#10 |
stevem garcia
Rep Power: 11 |
I I follow these procedures .. then after I typed ./AllMake.stage4 inside ThirdParty, this error appeared:
======================================== Starting ThirdParty AllMake: Stage4 ======================================== Using system installed QT Package name : ParaView-4.0.1 Package URL : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/ParaView-v4.0.1-source.tgz RPM spec file name: ParaView-4.0.1.spec Additional flags : --define=_qmakePath $QT_BIN_DIR/qmake Updating the ThirdParty environment variables before building package ParaView-4.0.1 RPM file name : /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm Making package ParaView-4.0.1 using RPM. Building package ParaView-4.0.1 using SPEC file : ParaView-4.0.1.spec. Optional args: --define=_qmakePath $QT_BIN_DIR/qmake Executing(%prep): /bin/sh -e /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.VwvK1g + umask 022 + cd /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/BUILD + cd /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/BUILD + rm -rf ParaView-v4.0.1-source + + /bin/tar/bin/gzip -xf - -dc /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/SOURCES/ParaView-v4.0.1-source.tgz + STATUS=0 + [ 0 -ne 0 ] + cd ParaView-v4.0.1-source + exit 0 Executing(%build): /bin/sh -e /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.YtUIAh + umask 022 + cd /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/BUILD + cd ParaView-v4.0.1-source + [ -n gcc ] + export CC=gcc + [ -n g++ ] + export CXX=g++ + [ -n -m64 -fPIC ] + export CFLAGS=-m64 -fPIC + [ -n -m64 -fPIC ] + export CXXFLAGS=-m64 -fPIC + [ -n -m64 ] + export LDFLAGS=-m64 + set +x Compilation options: _withVerbose : false _withMesa : false _withMPI : false _withPython : false _withQt : true _qmakePath : /usr/bin/qmake _mesaIncludePath : Undefined _mesaLibPath : Undefined _pythonLibPath : Undefined + addCMakeVariable VTK_USE_TK:BOOL=OFF + [ -n VTK_USE_TK:BOOL=OFF ] + CMAKE_VARIABLES= -DVTK_USE_TK:BOOL=OFF + shift + [ -n ] + addCMakeVariable BUILD_SHARED_LIBS:BOOL=ON VTK_USE_RPATH:BOOL=OFF + [ -n BUILD_SHARED_LIBS:BOOL=ON ] + CMAKE_VARIABLES= -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON + shift + [ -n VTK_USE_RPATH:BOOL=OFF ] + CMAKE_VARIABLES= -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF + shift + [ -n ] + addCMakeVariable CMAKE_BUILD_TYPE:STRING=Release + [ -n CMAKE_BUILD_TYPE:STRING=Release ] + CMAKE_VARIABLES= -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release + shift + [ -n ] + addCMakeVariable PARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON + [ -n PARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON ] + CMAKE_VARIABLES= -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON + shift + [ -n ] + addCMakeVariable PARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON + [ -n PARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON ] + CMAKE_VARIABLES= -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DPARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON + shift + [ -n ] + addCMakeVariable QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake + [ -n QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake ] + CMAKE_VARIABLES= -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DPARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake + shift + [ -n ] + echo CMAKE_VARIABLES: -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DPARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake CMAKE_VARIABLES: -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DPARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake + mkdir -p ./buildObj + cd ./buildObj + cmake -DCMAKE_INSTALL_PREFIX:PATH=/home/a/foam/foam-extend-3.1/ThirdParty/packages/ParaView-4.0.1/platforms/linux64GccDPOpt -DVTK_USE_TK:BOOL=OFF -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DCMAKE_BUILD_TYPE:STRING=Release -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DPARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake .. /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.YtUIAh: 80: /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.YtUIAh: cmake: not found error: Bad exit status from /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.YtUIAh (%build) RPM build errors: Bad exit status from /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/tmp/rpm-tmp.YtUIAh (%build) Installing package: ParaView-4.0.1 Uninstalling ParaView-4.0.1 using RPM: ParaView-4.0.1-linux64GccDPOpt.x86_64 Installing ParaView-4.0.1 using RPM file: /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm error: open of /home/a/foam/foam-extend-3.1/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.0.1-linux64GccDPOpt.x86_64.rpm failed: No such file or directory Done installing package ======================================== Done ThirdParty AllMake: Stage4 |
July 23, 2014, 10:14 |
#11 |
stevem garcia
Rep Power: 11 |
Can I use paraview from openfoam-2.3 installation to see my results from cases of foam-extend? If yes .. I'll install it (openfoam 2.3), because this problem is difficult to solve ...
July 24, 2014, 05:03 |
#12 |
Ayhan Eses
Rep Power: 17 |
you could download and install paraview as a standalone software from below site.
http://www.paraview.org/download/ it is not short way but i use for now. then create a dummy file named "anything.foam" in your case folder, open paraview File -> Open -> change "Files of type" to All Files (*) select "anything.foam" file double click. i hope more professional helps come. best regards. |
July 24, 2014, 09:20 |
#13 |
Rep Power: 18 |
You can probably also use the paraFoam version from an OpenFOAM installation by writing a short script that sources the OpenFOAM version that includes paraFoam, start paraFoam and source the OF-Extend version again.
July 26, 2014, 11:24 |
#14 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@steven123: The error message you showed in post #10 is letting you know that cmake is not installed: Quote:
sudo apt-get install git-core build-essential binutils-dev flex \ zlib1g-dev qt4-dev-tools libqt4-dev libncurses5-dev libiberty-dev \ libxt-dev rpm mercurial graphviz openmpi-bin libopenmpi-dev cmake Code:
sudo apt-get install git-core build-essential binutils-dev flex zlib1g-dev qt4-dev-tools libqt4-dev libncurses5-dev libiberty-dev libxt-dev rpm mercurial graphviz openmpi-bin libopenmpi-dev cmake Best regards, Bruno
February 4, 2015, 04:24 |
#15 |
Rep Power: 14 |
same problem here. following the instructions here to use system installed paraview didn't work
http://www.tfd.chalmers.se/~hani/kur...OwnLaptop.html Problem with this uncommenting and running this line Code:
sed -i -e 's=\.OpenFOAM=\.foam=' foam-extend-3.1/bin/paraFoam And I guess there are implications when you do this, it changes the right file but it wouldn't work when running paraFoam in foam 3.1 extend Code:
sed -i -e 's=\.OpenFOAM=\.foam=' bin/paraFoam Last edited by wyldckat; February 4, 2015 at 14:56. Reason: Added [CODE][/CODE] |
February 4, 2015, 14:59 |
#16 |
Bruno Santos
Rep Power: 128 |
Greetings haze_1986,
Sorry, I'm confused by your description Does the last command line you provided fix the problem or not?
Bruno
February 5, 2015, 01:15 |
#17 | |
Rep Power: 14 |
Just a detailed explanation to what I have done and the error message: Code:
sed -i -e 's=\.OpenFOAM=\.foam=' foam-extend-3.1/bin/paraFoam Code:
sed: can't read foam-extend-3.1/bin/paraFoam: No such file or directory Code:
sed -i -e 's=\.OpenFOAM=\.foam=' bin/paraFoam I followed the compilation instruction to compile foam extend 3.1, no errors in the compilation log but in the foam 3.1 extend environment I am unable to run paraFoam, it will say that paraview is not installed. Last edited by haze_1986; February 5, 2015 at 05:43. |
February 5, 2015, 15:29 |
#18 | |
Bruno Santos
Rep Power: 128 |
Hi haze_1986,
In other words, what were the exact commands or steps you've followed to install ParaView? And if it's installed on your system, then what do these commands give you? Code:
which paraview ls -l /usr/bin/paraview Bruno |
February 5, 2015, 15:37 |
#19 | |
Rep Power: 14 |
In the f31 environment, which paraview does not give me anything, ls -l /usr/bin/paraview gave an error Code:
cannot access /usr/bin/paraview: No such file or directory which paraview gave Code:
/home/haze/OpenFOAM/ThirdParty-2.3.x/platforms/linux64Gcc/ParaView-4.1.0/bin/paraview Code:
cannot access /usr/bin/paraview: No such file or directory |
February 6, 2015, 08:48 |
#20 |
Bruno Santos
Rep Power: 128 |
Hi haze_1986,
Then all of that means that ParaView is not installed in your system. And that the ParaView version you have on OpenFOAM 2.3.x was built specifically for OpenFOAM 2.3.x, therefore it's not installed as a "system installed" ParaView version. Which Linux Distribution are you using? Because installing the system ParaView version depends on the Linux Distribution you are using. Best regards, Bruno |
Display Modes | |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
fvSchemes in FOAM extend 3.1 | Shenan | OpenFOAM Running, Solving & CFD | 3 | December 22, 2014 09:45 |
