March 26, 2017, 11:13 |
paraFoam can't open STL file
Emre
Rep Power: 10 |
I have an annoying problem. I can't open STL file which is in constant/triSurface folder. STL file is working properly. So I think my error is about installation. Screenshot from 2017-03-26 18-01-39.png I clicked console view: Code:
p, li { white-space: pre-wrap; } ERROR: In /home/emre/foam/foam-extend-4.0/ThirdParty/rpmBuild/BUILD/ParaView-v4.4.0-source/VTK/IO/Geometry/vtkSTLReader.cxx, line 461 vtkSTLReader (0x5a63e00): STLReader: error while reading file /home/emre/Desktop/foam-extend-4.0/run/modifiedsolver/constant/triSurface/IB_block.stl at line 287: unable to read reading point. ERROR: In /home/emre/foam/foam-extend-4.0/ThirdParty/rpmBuild/BUILD/ParaView-v4.4.0-source/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkPVCompositeDataPipeline (0x5b80c20): Algorithm vtkFileSeriesReader(0x5b80040) returned failure for request: vtkInformation (0x556f7b0) Debug: Off Modified Time: 305221 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 1) foam/foam-extend-4.0/ThirdParty/rpmBuild/BUILD/ParaView-v4.4.0-source/VTK/IO/Geometry/vtkSTLReader.cxx, line 461 Code:
catch (const std::runtime_error &e) { vtkErrorMacro("STLReader: error while reading file " << this->FileName << " at line " << lineCount << ": " << e.what()); return false; } foam/foam-extend-4.0/ThirdParty/rpmBuild/BUILD/ParaView-v4.4.0-source/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 Code:
// If the algorithm failed report it now. if(!result) { vtkErrorMacro("Algorithm " << this->Algorithm->GetClassName() << "(" << this->Algorithm << ") returned failure for request: " << *request); } return result; |
March 26, 2017, 14:55 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: Do you have the same problem if you run this command:
paraview $FOAM_TUTORIALS/immersedBoundary/cylBumpInterIbFoam/constant/triSurface/ibCylinder.stl
March 27, 2017, 04:15 |
Emre
Rep Power: 10 |
Thank you very much for reply.
I run and opened it. There is no problem. I can see STL cylinder. BTW after closing ParaView, I received this on the terminal. I think it is not important because I can open an STL file at all: Code:
Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! error.png I will also attach my STL to next post because I can't attach this one. Thank you very much Bruno, for this and for all of your effort on openFoam, foam-extend. Sincerely |
March 27, 2017, 04:38 |
Anton Kidess
Rep Power: 29 |
Did you use the same Paraview version on your Laptop? I recall there was a Paraview version with an STL reader bug.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
March 27, 2017, 04:51 |
Emre
Rep Power: 10 |
Here I attached STL file that gives me error which does not supposed to do so.
It is in text file due to the restriction of uploading it in STL extension. So you can simply change its extension to .STL from .TXT. IB_block.txt.zip |
March 27, 2017, 04:55 |
#6 | |
Emre
Rep Power: 10 |
The working version is 4.3.1 on openSUSE 42.1. This error I'm dealing with is 4.4.0 on ubuntu 16.04. Sincerely, Emre |
April 25, 2017, 12:56 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Emre: Sorry for taking so long to get back to you on this. Anton is right, ParaView 4.4.0 has a bug when it comes to loading STL files, as reported here: https://bugs.openfoam.org/view.php?id=1887 You will have to either have to:
Best regards, Bruno
foam extend 4.0, paraview 4.4.0 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
