Having to reinstall Openfoam utilities inside docker after every log in
Dear all,
I am trying to install cfMesh. I am using a openfoam on debian with docker. I can install cfMesh and everything runs just fine. When I exit the docker however, my installed cfMesh utility is removed and I have to reinstall it every time I log into docker image. Is there any way I can make the openfoam utilities I install permanent so I dont have to reinstall them after every log in? Thanks Sohail |
Quick answer:
Sohailr
a)When you are running OpenFOAM from OpenCFD using docker then , changes will be there in docker container untill or unless you have deleted the container. |
