[OpenFOAM.org] Is it necessary compile ThirdParty?
Old   May 14, 2017, 15:54
Default Is it necessary compile ThirdParty?
gu1
Guilherme
gu1 is on a distinguished road
I use OF 4.1 for my researchs. However, I need to install OF 3.0.x, which is required for the installation of CFDEM.
Can I only install OF 3.0.x? Not compiling the ThirdParty.
If I want to run a case in OF 3.0.x, can I? Under these installation conditions.
gu1 is offline   Reply With Quote
Old   May 27, 2017, 06:37
Retired Super Moderator
Bruno Santos
Quick answers:
  1. It is possible, but it depends on the features that you are planning on using with OpenFOAM 3.0.x.
  2. If you plan on decomposing the cases by using Scotch, then you need to at least build Scotch by using the one on "ThirdParty-3.0.x".
  3. ParaView doesn't need to be built. You can use the one from 4.1 on another terminal.
  4. You can have multiple installations, by following the instructions given here: https://openfoamwiki.net/index.php/I...nFOAM_versions
installation guide, installation of openfoam, openfoam, openfoam 3.0.x, thirdparty
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) Milan2013 OpenFOAM Installation 23 April 20, 2017 05:49
[OpenFOAM.org] Installing OpenFOAM 2.3.1 on Mint 17 - ThirdParty stuff not seeming to compile MikeHersee OpenFOAM Installation 2 January 4, 2015 05:32
Thirdparty mesquite-2.1.2 compile fix for newer gcc kmooney OpenFOAM Bugs 3 May 10, 2012 09:27
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
