[OpenFOAM.com] v1612+ cmake-VERSION error during install |
May 25, 2017, 08:19 |
Brian
Rep Power: 8 |
I am attempting to install OpenFOAM v1612+ by following the instructions found here: https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL.
I am running into an error during step 9, specifically this part "./makeCmake > log.makeCM 2>&1". It finishes almost instantly and the log file simply contains: # cat log.makeCM Error: see 'makeCmake -help' for usage The cmake-VERSION was not specified I'm at a loss as I've installed OpenFOAM 4.1 with the instructions without issues several times. Edit: I am installing on Scientific Linux 6.8. Edit 2: I just tried on our new SL7.2 cluster with the same results. Last edited by bbrown57; May 25, 2017 at 09:55. Reason: Adding additional info |
May 27, 2017, 07:44 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Brian,
My apologies, I have now revised the instructions on the wiki: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.8 The problem was that I assumed that OpenFOAM+ v1612+ was using the same "makeCmake" script as OpenFOAM 4... but it isn't and back when I wrote the instructions, I somehow missed that detail when testing the instructions. The missing detail is that we need to run makeCmake like this: Code:
./makeCmake cmake-3.2.1 > log.makeCM 2>&1 Bruno
June 5, 2017, 10:10 |
Brian
Rep Power: 8 |
This fixed the issue. Thank you.
[PyFoam] Problems with installing PyFoam | Christoph_84 | OpenFOAM Community Contributions | 34 | October 26, 2021 11:25 |
[OpenFOAM.com] MacOS via Docker: Cannot install Paraview with Qt and CMake | guessit1000 | OpenFOAM Installation | 0 | July 15, 2018 14:42 |
How to install an old version of Openfoam on OpenSUSE 13.1 | Wang@nitech | OpenFOAM Installation | 2 | October 13, 2014 23:03 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Install development version on Ubuntu | hsieh | OpenFOAM Installation | 9 | December 31, 2007 08:18 |
