[Other] Looking for instructions or package that provides static builds of OpenFOAM |
June 24, 2017, 14:26 |
Hi David,
I am also need to run a solver on a machine which doesn't have OF installation. Can you please share if you were able to reomve the segmentation fault you were getting after using Ermine. Thanks in advance Regards, Aashay [Moderator note: Moved from Statically Compiling OpenFOAM Issues] Last edited by wyldckat; June 25, 2017 at 12:26. Reason: see "Moderator note:" |
June 25, 2017, 12:37 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I've moved your question to a new thread, because the other two threads where you asked were really outdated (were from 2008 and 2009).
At the moment, I'm not familiar with any instructions or packages that provide OpenFOAM in a static build form. After some searching, last time I looked into this was back in 2011 and is documented here: Anyone succesful on static executable solver? Either way, if you can provide more details regarding in which Linux Distribution and type of machine you are trying to use OpenFOAM in, it would make it a lot easier to suggest an alternative to you. Because it is possible to build/install OpenFOAM without administrative permissions, namely to install it as normal user in your own account.
Display Modes | |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
[OpenFOAM.org] Building OpenFOAM 3.0.1 on Ubuntu 16.04 - failed | erico | OpenFOAM Installation | 30 | February 2, 2017 10:24 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 12:50 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
